Results 1 to 14 of 14
    Aug 2016
    Spokane, WA
    Default Power Steering Comparison
    In comparing a 2018 with my 2016 RT LTD Power Steering it seems that the 2018 responds or steers effortlessly even at stand still My 2016 does not...
    has anyone noticed this? Before I pull the trigger on my 1 month out of warranty Spyder to see if indeed it's a problem thought I'd throw this out
    Jun 2010
    Las Vegas
    The DPS is different in the late 17 and 18 models although I can’t tell you if one feels different than the other. I had a 14 RT and now have a 17 F3T with the new DPS so that would be an apples to oranges comparison.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2016
    Clifton Springs, NY
    Quote Originally Posted by DUFF View Post
    In 2017 the power steering unit (DPS) was changed. I don't know what the change was exactly but I do know my 2017 F3L steers much easier than my 2015 RT especially at a standstill and at slow speeds. I can maneuver the F3 in and out of the garage and a parking lot with ease compared to my RT.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    May 2017
    TX
    I have a 2017 RTS and the PS is hard at standstill.
    My wife has a 2017 F3L and the PS is as easy as can be at a standstill.
    The RTS has been that way since I got it. So to me, it is normal.
    2017 RT-S , Pearl White
    Apr 2015
    Brockville ONT
    My 2018 RT is much easier to steer than my 2015 RT was.
    2018 RT Anniversary , Brake pedal extended
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Same here, I've noticed a difference between my previous 2014 and my current 2018.
    2018 RT LTD , Black
    Sep 2009
    La Valle, WI
    My 15 RTS would not turn at idle. Had to start moving. My 18 F3L steers effortlessly at idle and moving. I love it. The 15 RTS was like moving a tank in tight parking situations. You would think BRP could offer an update for older ones to steer easier.
    2018 F3 Limited , Oxford Blue
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    I have a '14 RTs which steers terribly on the driveway or other tight spots compared to my 2016 F3L.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Jun 2010
    Las Vegas
    Quote Originally Posted by dag62 View Post
    Not all 2017’s have the new DPS, so it is possible that yours does not have it. If a 17 requires BUDS2 then it has the new DPS, if it can communicate with BUDS then it is the old version.
    2010 RT- 622
    Default WELLLLLLL NOW THAT YOU MENTION IT
    Quote Originally Posted by wrb3004 View Post
    The F-3 is about 200 + lbs. lighter, the suspension is a little different, and the weight distribution is different ..........so why do folks think they will steer the same ??? .............jmho .........Mike
    Dec 2017
    usa
    Default weight
    Per BRP spec's the '17 RT Limited weighs 1012 lbs. and the F3 T weighs 948 = 64 lbs.
    Keep it honest!
    Have a nice day and enjoy the weekend,
    als
    Default HONEST VS. COMMENTS
    Quote Originally Posted by als View Post
    Keep it honest!
    als
    .......... I'm so glad you found my EYE quickly ..... now please remove your thumb I have to sneeze .................. Mike ...........PS I wish you a much better day and enjoy your weekend too.
    Sep 2009
    La Valle, WI
    The 2018 F3L weight is 987 so there is only 25 pound difference.
    Apr 2016
    Raceland, La.
    Default : Power Steering Comparison
    Test Drove 2018 RT and the there is a HUGE difference from my 2011 RT !!!
    MUCH IMPROVED DPS !!!
Tags for this Thread
