Results 1 to 20 of 20
    Sep 2009
    La Valle, WI
    Default Handlebar slipping with Rox Risers Help
    I installed the Rox risers on my 2018 F3L and I cant get them tight enough to stop slipping. There in no knurling on the handlebars. The bars want to slip with average pressure on them. I tried a prick punch and hammer to mar the inside surface. Didn't help. What now any advice would be helpful.
    2018 F3 Limited , Oxford Blue
    Default RISERS
    Quote Originally Posted by JP58 View Post
    I can't speak directly about the ROX brand ....but when I bought risers from " RSI " they sent shims because all handlebars are not the same size ......How close to the exact diameter is the ROX brand...... di you get SHIMS ??? .........Mike ..........PS.... PM Prairie Spyder ( Patti ) I'm pretty sure She has them on Her F-3
    Sep 2009
    La Valle, WI
    No shims. I may have to make some. A friend said use pop can to make shims.
    Active Member Ccol's Avatar
    Jan 2013
    Sunshine Coast QLD Australia
    Wet-N-Dry emery / sand paper works well in the bar clamp.....
    2017 F3s-Daytona...After market top-box,- Diy Sports rack,- Diy Windshield & brackets - Sena 20s,- Shad side cases,- Drivers backrest,- 660 Garmin,- Altimate floor boards, - Diy Belt Guard, - Sinister Exhaust,
    Jul 2010
    Las Vegas, NV
    Default Two options
    Return the them; mine don’t slip.
    set your bars where you want them, drill through, put a screw in. They won't move.
    Your call.
    Joe Meyer
    Jul 2018
    New Jersey
    !0-4 on Wet-N-Dry emery / sand paper.
    Joe
    2018 F3L , Blue
    Sep 2014
    USA
    I did the set screw trick as mentioned already on my old Harley bars many years ago and never had another problem after that.
    May 2016
    Nashville, TN
    Default Fox risers
    I had them on a Honda ST1100 and finally trashed them as never able to stabilize.
    Sep 2009
    La Valle, WI
    I drilled and taped the risers caps. Added 2 bolts. All is good unless the lower one moves.🤔
    Sep 2016
    clark county indiana
    Default photo
    can you get a photo of the risers , we have someone here that might be in need of risers , just so they might get an idea of what handle bars up will look like !
    Invalid Emails
    Cloquet Minnesota
    My ROX risers are tight and have worked great so far.
    Sep 2009
    La Valle, WI
    Here's mine. I had to drill, tap and add 2 screws to stop slippage.
    Apr 2017
    North Central Florida
    In the past when I had a similar problem, some double-sided fiberglass carpet tape fixed it.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Tighten down the front bolts all the way then tighten down the rear. Many folks on other motorcycle threads say this is the proper way to tighten them and they don't slip.
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    May 2012
    North Las Vegas
    What am I doing wrong? The right one turns the ignition key off when I make a tight right turn, I have it extended out as far as I am comfortable with.
    Rick
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Quote Originally Posted by rtotten View Post
    Rick
    first thankyou for your service …………. Rox makes a few different styles of RISERS ….. maybe yours are different from others ???? ………. just a thought …. Mike
    Bossier LoUiSiAna
    I'm confused,the U FIT system didn't fit or you just wanted something different? Glad you found a fix
    Sep 2012
    Junction City, KS, USA
    The only time my handlebars slipped after the Rox risers were installed was when Cruzr Joe sat on my F3T and then used them to pull himself up. Maybe they would slip if it really leaned on them, but I try to push up from my feet instead.
    He broke your bike?!?
    Give my Attorneys a call:
    Sep 2009
    La Valle, WI
    Rox Risers will give you more adjustability because you have 2 pivot points. You can move the riser up or down and the handlebar up and down till you have the right fit.
