Results 1 to 18 of 18
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Painted rear fender/mud flap
    I found this picture on another site, and was wondering, is this something someone painted? Or is this something you can buy?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    they painted it or had someone do it. maybe the forum member will
    chime in.
    [joyce & irvin toms]
    Jun 2018
    HAYMARKET,VA
    It looks awesome! So much better than the black!
    Baja Ron Sway Bar
    Key Cover from Ebay
    Nov 2016
    Upstate NY
    I painted mine to match also.
    Not too difficult. Clean really really good, DO NOT SAND OR SCUFF, spray on some plastic adhesion promoter, color, and clear. Did mine with spray cans. Been over a year and its still holding up well. No paint peeling or chipping.
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Joel The Biker View Post
    That looks awesome Joel! Do you know what brand names to look for?
    Baja Ron Sway Bar
    Key Cover from Ebay
    Nov 2016
    Upstate NY
    you can try the colorrite website. If yours is pearl white, there will also be a midcoat.
    Joel,
    Nov 2016
    Upstate NY
    I checked the color-rite website and they do have pearl white. You will need Adhesion promoter, gray primer(if you skip this step it will be hard to get coverage with white over black plastic.), base, topcoat, and clear. Probably going to cost you $100 or more. Take your time if you do it. Prep is everything. Clean Clean Clean. I recommend buying the prep wipes on colorrite also $3.
    Jun 2018
    HAYMARKET,VA
    Awesome. Thanks! Something I definitely want to put into my list of wants/needs to do.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Vermont
    Joel, nice job, I was wandering if anyone on this site had painted there's in the color. Since I have the painted dashboard.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    painted all the black to match and the dash and vents plum crazy purpleIMG_20160417_123911129[1].jpgIMG_20160417_123921065[1].jpg
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
    Dec 2016
    Iowa
    How difficult is it removing the piece to paint?
    2016 RT Limited , Black
    May 2016
    mt morris il
    ppg only offers it in water base, no solvent.
    see below
    http://www.lamonstergarage.com/news/spyder-paint-codes/
    Sep 2014
    GAFFNEY SC
    Quote Originally Posted by Tyris View Post
    Not that bad for.the fear tender. Just have to be careful with the ride tabs
    JIM EVANS
    Sep 2014
    GAFFNEY SC
    You will want to hot it with a scuff pad adhesion promoter. Primer then sand may have to reprised if you want to re.ove the texture. Then base midcoat and clear
    JIM EVANS
    May 2016
    mt morris il
    what paint co. did you use?
    Sep 2014
    GAFFNEY SC
    Used ppg as have access to mixing system. But have also used colof.rite and it is fine
    JIM EVANS
    Active Member remark2013's Avatar
    Sep 2014
    Los Alamos, New Mexico
    I have on both of my Congaic bikes. I had to have the color custom matched at an auto paint dealer. Then like Joe said, clean, clean and clean some more. then I used and adhesion promoter and primed the panel and sanded it until smooth, then used a sealer then color then clear. Looks awesome!
    Kent
    Ride Safe All
    2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
