Results 1 to 10 of 10
    Sarasota Florida
    Default 2016 RT Heated Grips
    HI all, I live in south west Florida, and heated grips are a total waste here. I've accidentally hit the switch several times while turning off the parking brake, and let me tell you, my heated grips work very well. But again, not needed. I would like to disable the switch or the grips, either way, with a temporary fix, just in case I decide to (shudder) take a trip into the cold north. But I don't want to just pull the connector off from the switch, which would leave it open to potential moisture issues.
    Thanks.
    Try to find a small piece of rubber block that you could cut in two and wedge each piece under the ends of the double throw switch. Neatly cut and fit no one would know they are there.
    Nov 2015
    Mooresville, In
    See if there is a fuse for the grips, if there is then just pull it and if you ever need them put it back in
    Ride safe
    2015 RT L , Red
    Apr 2017
    North Central Florida
    Quote Originally Posted by Marvin2488485 View Post
    Ride safe
    I'm in the same basic situation......but have been too lazy to look up the fuse assignment.
    Even when I lived "up north" I didn't ride when it was cold enough that you needed more than riding gloves.
    Ride safe
    There is not. The grips are on the same fuse as the horn and rear shock compressor. The ACS and grip heaters are controlled by the load shedding relay.
    Sarasota Florida
    Well thanks for all the input. I guess I'll try an old Navy Electronics school trick and put some scotch tape on the connectors. As this is low voltage the thin tape will block the current with out being so thick that it is difficult get the plug back together.
    Have fun and ride safe.
    Aug 2013
    Northern California
    This almost never happens anymore! You will get used to it, and if you sell it, people may want that feature!
    Apr 2017
    Quote Originally Posted by Rishathra View Post
    BUT.....any kind of tape will likely "foul" the connection if left on there very long.
    Just unplug the output wire at the switch and secure it........and insulate as necessary.
    No need to plug it back in.
    (I just tried to do this on mine and found that the switch pops out easy enough but it won't come up far enough to get to the connections on the bottom......I assume because there isn't enough slack in the wires. Too bad. That would have been REALLY easy.)
    May 2012
    Panama City, FL
    I have found it useful. I've used mine a few times in the winter, but it does get colder here in the panhandle. Dale
    Jul 2008
    Mesa AZ
    Default I like the wedge idea!
    "Try to find a small piece of rubber block that you could cut in two and wedge each piece under the ends of the double throw switch. Neatly cut and fit no one would know they are there."
    I'm going to my 'junk' drawer to look for some pieces to cut and wedge in both ends of that rocker. In AZ I don't need heated grips!
