Page 1 of 3 123 LastLast
Results 1 to 25 of 57
    Jul 2017
    Woodbine, Iowa
    Default My One complaint of a Spyder
    I have had my Spyder for about one year now. It is a 2015 RT SE6. When I first got it I had several things I did not like about it but have corrected or learned to accept most everything. The one thing I do not like is when you first start it and put it into gear the bang noise it makes. I know it does not hurt anything but it is annoying. I have learned to shift it without any noise and real smooth. You do have to pay attention when shifting. When I first got it I hated when you turned the key on and had to wait to push the mode button to start. I have got use to that so I know when I walk up to it I just turn the switch on and by the time I am in the seat it is ready to start. I was just curious if anyone else felt this way?
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by gerald37 View Post
    I have a 2018 RT and got used to waiting to press the mode. What I still don't like is the clancking noise (sounds like something is breaking) In first or reverse. My dealer says it's normal and not to worry. There was discussions on this board regarding that. I guess just get use to it and enjoy your ride...
    Oct 2014
    Fort Mill, SC
    I think a lot of use feel that way. That bang is due to the constant mess transmission. All bikes do that.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    My 2005 Goldwing clunked whenever I put it into gear, though not as loud as the Spyder. Just like I used to tell my kids, "You can't have everything!"
    May 2016
    Spring Hill, TN
    Just one complaint? I've had mine a couple years now, a '12 RT-Limited. Coming from strictly Harleys for close to forty years it was quite an adjustment for me, as I'm sure it is for most Harley riders. Since I'm a DIY person, working on the Spyder can be intimidating at first; from popping the mirrors off to removing the panels to doing ANY work in the engine area. I finally decided to go into full crew chief mode (I used to work on F-4s and F-16s in the USAF) and just dive in. True, it's a regular pain in the donkey to work on, but there's a ton of info on this site that help every step of the way. As far as the operation of it...once I got out of the "Harley only" attitude it's a pretty trick ryde. I like it, and most importantly, the bride likes it. But in agreement with you, initially it was unnerving. And since you have a "newer" one, just be thankful the battery is not under the seat buried in a hell hole
    Ryde safe, and if you're ever in the Nashville area, hit me up. Coffee's on me.
    Apr 2017
    North Central Florida
    You need to just get over that.
    Pretty much ALL motorcycles bang into gear the first time each ride; it is a characteristic of the constant mesh transmissions.
    The Spyders are a bit louder than most.......for some reason.
    AFTER the first shift though, mine shifts quieter than most other bikes I've had.
    P.S. I know this doesn't sound logical but it works on some other machines: Try rev'ing the engine a bit once or twice before you put it in gear......with the clutch pulled in if you have a manual. Give it a try. I haven't yet.
    Oct 2017
    Pennsylvania
    Default I like it
    I actually like it when it makes a solid "clunk" when you shift it into first. It's like you're doing something very mechanical and important. I usually follow it up with a grin
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by iw12surf View Post
    I am like you. I have been riding motorcycles for 63 years. I have had about every brand there is. It was quite an adjustment for me also. I have always done all my own service work on all my motorcycles. The Spyder is a bit more work than most motorcycles but I have had about every piece of plastic removed several times. Like you said there is a lot of help on this site and I have used it. I did put the magic mirrors on mind and that helps removing them. I really don't mind servicing it. Like I said in my original post I don't like the noise it makes going into gear when staring it. Thanks for the come back.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    My Goldwing's did the same but sure was not near as loud.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    Mind is not a manual but it does seen to help a little if I rev the engine for a little bit in neutral and get the RPM down just a little.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    The wait/mode problem got solved with the 2017's--they tell me.
    I am not going to worry about the clunk when they shift into gear. They (as in all motorcycles) do that.
    Apr 2012
    Florida
    You want to hear a "clank"? Ride a Victory! Tom
    2020 Petrol Blue Metallic RTL
    If you can't get used to : sell the bike, and drive a Toyota instead!
    All motorcycle transmissions are going to do that. It's the way that it is...
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Starting on a 2017
    I know there is a trick on the newer Spyders to bypass the wait when starting, could someone reply with that info ??
    thanks johnv
    Mar 2017
    Oviedo Fl
    Default By Pass at startup
    Turn on key hold in the mode button and start the bike.
    Newport, VT
    Default Mode button
    On newer Spyders you can press the mode button almost immediately after turning the key and it will start.
    May 2013
    Apex, N.C.
    I also hate the clunk, but I have found that it seems to be less pronounced if I let the engine warm up a little first. It also helps if the bike is slightly rolling in the direction of which you want to go. In other words, if you are going to reverse, let the bike be rolling back a little. If you are going into first, be rolling forward a little. It tends to make less of a clunk, and sometimes non at all.
    Quote Originally Posted by Red RT-S View Post
    Yup!
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    I am able to push the mode button at any time and start the bike meaning it isn't necessary to wait until the screen changes and I have a 16 RTL. I came from an 05 Goldwing and have no complaints to speak of. Just wish I'd would have made the switch sooner. Chris
    2021 Spyder RT Liminted , Marsala Red in Black
    Aug 2013
    Northern California
    NO,
    Aug 2013
    Northern California
    Quote Originally Posted by johnv50 View Post
    thanks johnv
    Turn key, press mode button then hit start!
    I usually disengage the parking brake first... and then hit "Mode"!
    Aug 2013
    Northern California
    ....but then you also have your foot on the brake pedal! Man this is getting confusing!
    Quote Originally Posted by Pirate looks at -- View Post
    To shift into 1st, but not for reverse!
    Mar 2018
    Oregon
    Default You don't really have to wait to press the mode button.
    You can press it even if the text is not yet on your screen and it will let you immediately turn on the engine!
    Quote Originally Posted by mbenazeraf View Post
    SPYDERGAL
