Results 1 to 12 of 12
    Active Member JCWeatherman's Avatar
    Aug 2015
    Lancaster County, Pennsylvania, USA
    Default Time for New Shocks
    Hi All,
    I have been riding my 2013 STL for about 4 years now. I have put 13,500 miles on it. I'm close to getting new tires, but I'm thinking I will get the shocks replaced also. Here are my questions:
    1. Should I do it?
    2. If so, what should I get? I see Elka Stage 2 and Fox mentioned. What is giving you the greatest success. I ride solo 80% of the time and the rest of the time is group riding with my bride on the back.
    3. Where do you get them? Dealer? Online?
    BTW, I have already changed the sway bar and links for Baja Ron models. The sway bar made a big difference. The reason I am considering new shocks is it seems a little mushy in tight curves, and in Pennsylvania we have a lot of tight curves!
    All the best,
    John
    2022 RT Limited
    • Garmin XT (I would be lost without it)
      Driving Lights (Very bright to improve my sight)
      Floorboard Lights and Turn Signals (I like to be seen)
      Passenger Armrests (So my wife doesn't fall off)
      Trailer Hitch (So we can bring more stuff with us)
      Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
      Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
    Default Depends...
    That is not a lot of miles and I would imagine your shocks are fine. If you are not having problems with the handling. If adjustable you could change the adjustment and note the difference. My rear shock has 40,000 miles (6 years) and works fine even double up. I did change a lot on the front end due to the ryding I do and put on the Fox Podium shock and happy with them....
    Dec 2015
    Oakley Utah
    Maybe you're looking for a way to justify the decision you have already made in your head?
    2014 RTL Platinum
    Faribault, MN
    Default Or.... BR Shock Adjusters for the '13
    Or consider BR's Shock Spring Pre-Load Adjuster Kit, there's another thread going on right now about them. I too doubt your shocks are already bad, but the adjusters do allow you tweak your stock shocks for a lot less than the Elka's or Fox's.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2015
    Default Clarification
    Just to clarify: I'm not saying that I NEED new shocks or that my shocks are bad. I'm just wondering if different shock would make a significant difference in handling. If new shocks or pre-load devices would make a great difference, I'm in, but I'm not just out to spend money.
    All the best,
    John
    2022 RT Limited
    Default Oh yeah !!!
    Quote Originally Posted by JCWeatherman View Post
    If your a spirited ryder you will feel the difference. I have wtih every step I made. Started with the swaybar, pitbull shock relocators, Fox podium shocks and BLUEKNIGHT911 shock relocators (moved them out another 11/2"). I do suggest whatever changes you make make them one at a time and then ryde for a while to see the effect of each...p
    Sep 2014
    USA
    Yes go with Baja Rons shock adjusters they will help with your twists and turns and not have to spend 700 bucks for new shocks.
    Yes they do help.
    Nov 2013
    Oro Valley Arizona
    Hi All,
    1. Should I do it?
    OK OK sorry, thought you said Socks! And I was wondering why.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2015
    Puyallup, WA
    I first went with the Baja ron bar..then switched to the Can-Am/Fox shock kit (thru ebay) right after i bought the bike. My bike only has 4700 miles on it now and corners like crazy with the Fox shocks and bar...that is riding solo. When riding double if feels a bit light up front (probably like a stock bike). Well worth if for single riding in my opinion.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by NSPYTE View Post
    Which bike are you talking about?
    2014 RTL Platinum
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    Default and my two cents.........
    I also have a '13 STL. I am not a spirited rider and most of my riding is 2 up. In my opinion, the stock suspension on the '13s were marginal to say the least,brand new. I now have 36K on mine and the original setup was sacked. Just 2 weeks ago I installed a new set of Elka stage 2 front and back, and what a difference. Now the tires just stay on the ground. Period! And my wife's back has fallen in love with that rear unit.
    I would suggest this. With that low mileage, I don't think your suspension is shot. If it really bothers you then by all means get the fronts. You will fall in love with the bike all over again.
    Aug 2013
    SF Bay Area
    Within 500 miles I had Fox shocks installed because coming from a two wheeler I felt the OEM suspension squishy. After 10k miles I noticed the front wheels were sagging so I adjusted the front shocks and figured they weren’t going to last much longer so I called Elka and talked to them. They recommended Stage 1 shocks as I don’t race nor ride with a passenger. I noticed a big difference. Problem is it was a LOT stiffer and the potholes were much more noticeable. They made for a rougher ride. Now on the RT I decided to go with BajaRon shock adjusters as I can dial them in to the comfort I want. I had 21k miles when I traded it in. The rear tire had been replaced but the front tires were barely half worn.
    2021 F3 Ltd , Magna Red
Tags for this Thread
