Results 1 to 25 of 29
    Mar 2015
    Brockport, NY
    Default Looking for gel seat cushion info
    I’ll try to keep this short. Eventually when we upgrade to our next spyder, thinking 2020 model, I want to get a Russell day long seat. Until then I would like to get something to “take the edge off” of the factory seat on our 2014 rts. Seat now is good for about an hour and half then gets uncomfortable for me and wife. I have an airhawk presently and it helps, but need to get something for my wife and she is thinking of a gel style cushion. Not wanting to modify existing seat, so probably not looking at an insert, but more of an on top the existing seat option.
    Would appreciate any thoughts and ideas that others may have, and thanks as always!
    2014 RT-S Pearl White
    Jun 2015
    Middletown NJ
    Default Gel Cushion Seat
    Worth a try? In Amazon
    Kieba Coccyx Seat Cushion, Cool Gel Memory Foam Large Orthopedic Tailbone Pillow for Sciatica, Back, and Tailbone Pain (Black)
    Kieba
    4 RTL , RTL 14- Value Acc full size pedal RTL 14 RTL Satin Gray,
    May 2013
    Indiana
    Depending on your budget for "taking the edge off the stock seat", you might want to take a look at the Large Airhawk-R.
    2021 Marsala Red Metallic RT Limited
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Default Purple.com
    Take a look at the seat cushions at http://purple.com
    I got the portable purple cushion this spring. Still evaluating since I haven't been able to do a long stint on it yet, but so far it looks very promising for a minimal investment!
    Apr 2017
    North Central Florida
    If left sitting out in the sun, gel gets REALLY hot......and stays HOT for a LONG time.
    I think that sheepskin might be a better choice.......and might be useful with the custom seat too.
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    The Airhawk R which is their largest really helps to extend the ride.
    Keep in mind that less air is better than too much air.
    Greg
    2015 RT Limited (White)
    Mar 2018
    Ontario ,way up north
    Butt Buffer gel cushion .Got mine at the Americade .
    2018 RTL , dark blue
    Mar 2015
    Brockport, NY
    Default So far.....
    My wife did try the Airhawk yesterday for the last hour or so of our trip home, but didn't love it. I am kind of liking that Purple website and may look at one of those and trim it a little to fit the passenger area??????
    I hadn't realized that Gel would get hot and retain the heat, thanks for that info!
    Apr 2017
    Quote Originally Posted by Brentc View Post
    Sometimes it feels good on a sore tush.......but mostly NOT.
    With an Airhawk--you sit "IN" it and not "ON" it. You have to play with the air pressure until you get it right for you.
    Alaska Leather also sells a Sheepskin/gel combo. I have used both when I had hip issues.
    May 2017
    Mesa, Arid-Zone-A
    I saw the Purple cushion at Bed, Bath & Beyond. They had a hard chair and cushion for a demo. It felt OK but I thought it was overpriced for what it was. Instead, I bought a MUCH less expensive kitchen floor mat and cut it into two pieces the shape of my old Air Hawk and put them both inside that cover. That gives me a gel pad about an inch thick and I have a sheepskin on top of that. I think the mat cost me 15 bucks. I haven't done long trips with that set up yet. But (butt) I can adjust it if needed. (Take one layer out, put air bladder back in, eliminate altogether, etc.)
    Semper Fi
    Nov 2012
    North Las Vegas, NV
    https://www.cyclegear.com/search?_utf8=%E2%9C%93&query=Gel+seat+pads&commit= Search
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Feb 2012
    Spring City,Utah
    One of our sponsors here motorcycledave sells a a gel cushion such as he uses for seats and beds for orthopedic equipment he makes.put this pad in my seat and it turned a 2 hour seat into an all day seat. Yes you do have to remove your seat cover to install it but it wasn't that hard and Dave was nice enough to answer his phone on a Saturday to help me thru it. I did buy an air staple gun but that was only about $25.Dave gives you everything else you need to do a good job with no visible wrinkles. It cost me only about $30 to do it.If you don't think you can do it any upholsterer can do it fairly cheap. having someone do it for you you still not be into it more then $125= gel.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2015
    Canton, Ohio
    I created a similar post over a year ago. I bought some suggestions that did not work, then took a great suggestion and made it better, now we can both Ryde for hours. Previously about an hour and a half and I was in pain.
    I bought the full Misty Mountain sheepskin and rode with it for a while, the improvement was very real and it works just as he promised, cooler in summer and warmer in winter.
    I then went to Jo-An fabrics and bought the 3 inch thick upholstery foam, took it home, cut it larger than both seats on the side to offer more hip support. I placed those pads under the MM Sheepskin and viola, my day long seat is in place. Seriously, this works, for less money than the Airhawk, and Misty Mountain will guarantee you like it or he will take it back. All of that being said, I really like the way it looks on the Byke. Since I bought mine I know of two of my friends that bought the skin and they are happy with just that.
    Joe
    Mar 2015
    Brockport, NY
    Default Trying something a little different first
    So, my wife being the innovator that she is, is thinking of trying padded bicycle shorts as a first step.......
    So I just smiled and said great idea hon!
    Mar 2018
    Oregon
    Can you post pictures?
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    SPYDERGAL
    Mar 2015
    Brockport, NY
    Default Probably not lol
    Quote Originally Posted by CA-SPYDR View Post
    Of my wife bicycle shorts, I don’t think that would go over well...
    LOL,
    Oct 2014
    Western Pa South Greensburg
    Default Plugger2
    My wife has one and she doesn’t like it.paid close to 100 bucks and it sets in cellar.airhawk is better.
    Aug 2012
    Central Coast, CA
    2020 RTL SE6
    Nov 2015
    Minnesota
    My wife would vote for a sheepskin. She has used one on multiple bikes for many years.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Default Jell seat
    Try SAM'S office he'll seats like $39. Great seat
    Apr 2017
    Quote Originally Posted by wingit3611 View Post
    More details, please.
    Who is SAM and where is his office ??
    Invalid Emails
    Oct 2015
    morgantown west virginia
    walmarts wholesale store.
    Nov 2012
    North Las Vegas, NV
    Motoskivies
    https://motoskiveez.com/
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    May 2017
    Perry Hall, Md
    I just let my ass get bigger. Good cushion, much cheaper
    2011 RT , Yes Blue
