Keep it Soft and Subtle
I use -- Glycerin --- just a smear -- around my old Porsche door seals for years. Keeping them from - drying out and cracking and staying subtle.
I now put just a smear around my rubber grommets of the push pins. You will like the difference, when pulling off the panel,and when replacing it. Available, at any drug store. Your welcome.g 1.jpg
Originally Posted by Many brands
I use -- Glycerin --- just a s mear -- around my old Porsche door seals for years. Keeping them from - drying out and cracking and staying subtle.
Do you mean supple?
2014 RTL Platinum
Some also like to spray the grommets with windex or a water spray..
I think I'll try the Glycerin to help ease the prongs into the grommets. I have never lost a side panel, but suspect that those that have come loose, didn't get hooked at the top of the panel, or punched the grommet through the frame due to being dry and stiff. Either way, they should wipe clean pretty easily before new applications and reinstallation. Thanks for the tip..
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
You just don’t want them to be greasy or the panel could fall off. We spray Windex on them as it dries without leaving any residue
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
re-
Yea - Supple ( Guess I don't get to use that word enough ) I could have said, Agile, Elastic, Limber, Pliable, Resilient, or Yieldig.
OR - just spelled it correctly.
The question is whether you're still supple enough to get out of that Porsche any more..?
2014 RTL Platinum
One of the best of many excellent tips I've received from Ann and Joe.
I may try glycerin; however there is a German product called "Gummi Pflege Stift" that is sold on eBay that also works great - I learned about this through Planet-9, the Porsche forum. The advantage of Gummi Pflege Stift is that it's a stick. No mess.
Hell, I used that back in the day on my new, ‘86 Goldwing for the same reason...I’ve used vaseline also. Glad that you reminded me...thanks.
Bruce
2014 RTS-SE6
Tri-Axis Handlebars
Sena BT Dongle
Sirius Radio
Dash bar
Show Chrome Trunk Rack
"You know that a politician is lying if his lips are moving"
A little dab'll do ya!
Found a small bottle at Wally world with a flip top cap. May just add it to my travel kit. DSCN2573.jpg
I agree with Ann: it might be better to just give them a spray of water...
You don't want those expensive body panels coming loose!
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
re-
Windex ? Ammonia , sprayed on rubber ?
I don't have any glycerin in the house .. how about KY?
JLohPhotos
For automotive seals, nothing better than Shin-Etsu grease, albeit more expensive than Vaseline
re-
KY.. That is super funny.. .
Originally Posted by UtahPete
Do you mean supple?
Nothing against you Utahpete but you sure do a great job of pointing out spelling mistakes. From now on I am going to read my posts very carefully and check my spelling as I know Utahpete will be watching.
2017 RT Limited
He has what you might call "a very critical eye". This is the result of an over controlling and attentive Mother!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
i just rub spit on the panel posts. costs nothing !
[joyce & irvin toms]
