Results 1 to 19 of 19
Thread: DESS ERROR
    Jun 2018
    maryland
    Default DESS ERROR
    It happened again. Stranded in Pennsylvania with the dreaded DESS ignition error symbol. I have a 2014 RT-S. The dealer acknowledges they don't really know what the cause is.
    Googling search shows many Spyder owners have suffered the same. Has BRP done anything to fix this problem? Swagman.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by swagman View Post
    It happened again. Stranded in Pennsylvania with the dreaded DESS ignition error symbol. I have a 2014 RT-S. The dealer acknowledges they don't really know what the cause is. Googling search shows many Spyder owners have suffered the same. Has BRP done anything to fix this problem? Swagman.
    It would be bike by bike. Most of us have not experienced that issue.
    2014 RTL Platinum
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    There is a post by DEANNE at least 20 pages relating to the problem along with other posts here.
    Do a SEARCH!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Dec 2015
    Oakley Utah
    Quote Originally Posted by PaladinLV View Post
    Do a SEARCH! AJ
    http://www.spyderlovers.com/forums/s...ght=DESS+error
    2014 RTL Platinum
    Sep 2014
    USA
    Yes DESS module and or ignition switch.
    Read the thread posted above.
    Turn key on and off a few times and or leave for awhile come back and try to start bike. Get home and have repaired ASAP>
    Default Oh yeah !!!
    There is a lot to read about it here. Once it fails the best thing is to have the dealer replace the switch and module. Otherwise it will only get worse. I would make sure they change both...
    Houston
    Wish I were closer, could have you up and running in less than 10 minutes and never see that error again. Truly wish more dealers would allow owners to just turn this defective system off.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Nov 2016
    Upstate NY
    I agree. Best thing to do is have the DESS disabled. Everytime I see these posts, I look to see where they live. I can disable it, but Maryland is too far.
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Do a SEARCH!
    AJ
    AJ, Name correction : Deanna777.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Also have the dealership open up a case with BRP. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jul 2017
    Woodbine, Iowa
    I was having the same thing happening more and more frequent. I purchased a DESS Module from Cheap Motorcycle Parts, Part #710004916. I replaced that and have never had the DESS Key again. If you don't have warranty it is not hard to change yourself.
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Sep 2014
    USA
    So you got that module replaced
    Jul 2017
    Woodbine, Iowa
    Yes, I did it myself. It is not a hard thing to change it just takes some time.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Sep 2016
    dilworth,minnesota
    Default getting my second one
    dropped it off at the dealer and waiting to get it back just as well haven't had time to ride any way.it better be back for Deadwood .
    Feb 2015
    Las Vegas
    Picky, picky, picky!
    Deanna
    2014 RT-S
    2014 RT/S , Black
    Feb 2015
    Las Vegas
    With the 2015, the module replacement corrected the vast majority of that model year.
    With 2014, you better get both replaced or you are headed for future problems.
    AJ
    2014 RT-S
    2014 RT/S , Black
    Vermont
    Most/and people on this site know me as Deanna777 or Deanna.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    AJ
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
Tags for this Thread
