Gold Plugs-1330 engine SOLD!
new, never used
engine MP18, retail $20.99
trans MP-01, retail $18.99
both for $30 shipped in lower 48
can take paypal
Reason: sold per post #5
Are they still for sale? I'm interested if PMK don't take them
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
![Quote](images/misc/quote_icon.png) Originally Posted by Ex-Rocket
Sent him the money...
Hope to maybe, do the big comparo.
Stock vs Dimple vs Gold. With all three in hand, hope have my friends X Ray them so we can see how they truly compare.
![Quote](images/misc/quote_icon.png) Originally Posted by PMK
I've heard that a few Dimple plugs broke off inside the engine when they were tighten down to much. Don't think I remember a Gold Plug breaking though. All plugs should be tighten to torque readings.
According to others, oem, Gold and Dimple have all broken off in the cases. As for correct torque, consider most drain plug threads are not clean nor dry, if the manual calls out a torque, most times that is for clean, dry threads, anything else, if torqued to specs will overtorque the fastener approximately 30 to 50% above the dry torque spec.
Consider too the quality and calibration of the torque wrench. Money saved on a less expensive torque wrench may be exponentially more expensive if damage occurs.
Great..!
Another fast sale...for an interesting reason. Hope to see the results of the testing.
As for the torque rule of thumb is to finger tighten then go a quarter of a turn more. Always use a new crush washer as it is not only the seal to prevent seepage/leaks but also absorbes the vibrations...
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
As for the torque rule of thumb is to finger tighten then go a quarter of a turn more. Always use a new crush washer as it is not only the seal to prevent seepage/leaks but also absorbes the vibrations... ![thumbup](images/smilies/thumbup.gif)
If I get the data, results will be posted on the new FB group for product evaluations.
DIMPLE VS. GOLD
According to others, oem, Gold and Dimpla have all broken off in the cases. As for correct torque, consider most drain plug threads are not clean nor dry, if the manual calls out a torque, most times that is for clean, dry threads, anything else, if torqued to specs will overtorque the fastener approximately 30 to 50% above the dry torque spec.
Consider too the quality and calibration of the torque wrench. Money saved on a less expensive torque wrench may be exponentially most expensive if damage occurs.
This was discussed / debated about 6 mos. ago ..... I have never seen a post about the Gold Plugs breaking !!! the Dimples have and quite a few ..... A member here did some measurements on the THREAD area .... and the Dimple plugs were thinner because the Magnet was wider ....... causing MORE metal to be removed from the thread part .... the difference in the strength of the magnets used is so small, measuring it would take a device we here couldn't afford....and both size magnets are more powerful than they need to be ...... good luck .... Mike
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
This was discussed / debated about 6 mos. ago ..... I have never seen a post about the Gold Plugs breaking !!! the Dimples have and quite a few ..... A member here did some measurements on the THREAD area .... and the Dimple plugs were thinner because the Magnet was wider ....... causing MORE metal to be removed from the thread part .... the difference in the strength of the magnets used is so small, measuring it would take a device we here couldn't afford....and both size magnets are more powerful than they need to be ...... good luck .... Mike ![thumbup](images/smilies/thumbup.gif)
I can easily borrow the Gaussmeter to compare magnetic field strength. Besides, even fancy ones these days are not that expensive.
Obviously, dimensionally checking will be easy. So comparing magnet dimensions is no problem for diameter.
Getting them X-Rayed to see inside vs cutting them apart may take a phone call or two.
If you have recolection of the topic / posts you mentioned, if you find them and link them, they may form a good baseline or determine if they are valid or not.
The way I read his reply was that the links you might be able to provide would maybe help him in analysing his results.
I absolutely did not think he was calling you a liar !!
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
Sorry you imagined these ideas and falsely read so much into a post.
Mike, sorry but he did not call you a liar.
Everyone, enough already. If anyone should be upset it could be me for having the hammer dropped as it has, but this is so petty I had no issue with any of it, and honestly, no ill intents were meant by anything posted.
However, at this point, I have realized, like I learned long ago, never argue or try to discuss two points with a cop, nothing good will ever come of it.
Anyone else interested or wanting to see how the drain plugs compare, the info will get posted on Facebook, most likely in the Spyder Technical group.
All the best everyone.
Initial comparison written and posted.
Find it at this Facebook Group: Can-Am Spyder Product Reviews by Users
For the non FaceBook people, this is the Word .DOC
Tried to upload the document here, but apparently with the text, images and tables, it exceeds the limits allowed and will not upload. Sorry.
FWIW, the diameter of the magnets on the long drain plugs, the Gold Plug is larger than Dimple Drain Plug and therefore the Gold Plug has a thinner wall thickness.
On the small drain plug, the Gold Plug has a substantially smaller magnet diameter, however I was under the impression it was the longer drain plug that fails.
The comparison compares the OEM Rotax / Can Am drain plugs to the Dimple Drain Plugs and Gold Plugs.
At this time, I have not yet measured magnet strength nor magnet length into the drain plug itself. Without doubt, the aftermarket magnets are both very powerful and substantially stronger than oem. This may not be a point, but certainly the stronger magnets have the larger field area and ability to draw particles out of the oil at a greater distance than oem.
I used aftermarket plugs on my RT BUT with the 2015 F3 I just do what the manual says and use the stock hardware??? $$$ Saved in my Pocket?
Sea Doo GTI-SE 90 Jet Ski!!
holy crap, Batman
all I did was sell some Gold Plugs.
How did that turn into so much yelling and screaming?
Dimple Vs. Gold
Thanks for correcting the info on the Wall thickness , so why was the ( reported ) failure rate higher for the Dimple Brand ??? .... I was pretty sure the Metal used was the same .... could the adhesive used to secure the Magnets make a difference ............ The WHY is IMHO going to remain a Mystery ......... Mike
Thanks for correcting the info on the Wall thickness ![clap](images/smilies/clap2.gif) , so why was the ( reported ) failure rate higher for the Dimple Brand ??? .... I was pretty sure the Metal used was the same .... could the adhesive used to secure the Magnets make a difference ............ The WHY is IMHO going to remain a Mystery ......... Mike ![thumbup](images/smilies/thumbup.gif)
The info I wrote and posted lists my assumption of what the drain plug materials are.
Oddly, with steel fasteners typically being stronger than stainless, another wrench was thrown into the failure question.
Both Dimple plugs are made of steel. Verified by strong magnetic attraction. I do not know the alloy, but expect it to be eqivalent to grade 5 or better.
Both Gold Plugs are made from stainless. Verified by minimal or no magnetic tendency. Again, not sure what alloy, but expect it to be typical of that used in quality hardware.
Oem drain plugs are mixed. The long plug is stainless, while the short drain plug is steel.
If adheseive is utilized to retain the magnets, vs a light press fit, I see no traces of it around the magnet perimeter.
I have my assumption of what happened, but need more info and facts before going there.
![Quote](images/misc/quote_icon.png) Originally Posted by ofdave
holy crap, Batman
Thank you for sending the drain plugs quickly. Not sure about all the arguing and bickering, but those Gold Plugs were the last item in order to not only compare the oem vs the Dimple brand vs the Gold Plugs brand.
There have been posts about all the drain plugs having some type of failure. The oem type are often condemned for not having the hex wrench flats and strip out the Allen or Torx portion. However one person did report snapping an oem drain plug off.
The Dimple plugs have been posted by a couple of people to have failed and required expensive repairs.
There have even been comments about Gold Plugs failing.
By purchasing those drain plugs, I now have in hand all three types. With that I put together a document discussing the similarities and differences, along with many photos and dimensions.
The sole goal in doing this was to allow those interested in magnetic drain plugs to compare, without bias from me, the drain plugs.
If you are on Facebook, the document is posted to the Can Am Spyder Technical group and owners review group.
Thank you very much for sending them quickly.
![Quote](images/misc/quote_icon.png) Originally Posted by Capt. Bob
Bwahahahahahaha. People sometimes like to fight on these two-dimensional forums. I can't believe that you didn't sell a representative sample of all available drain plugs so the end user could make up their own mind ![yikes](images/smilies/22yikes.gif) Now the buyer will always wonder, "Did I get the right drain plugs??????" And now I am not wondering as much why you are selling your Spyder ![Stick Out Tongue](images/smilies/tongue.png) I quit another hobby forum this week because I frankly got sick and tired of all the BS. The nice thing is that we can all exercise complete control and choose to read or disregard anything we see on the Internet ![yes!](images/smilies/pepper2.gif)
These Gold Plugs were used, in a manner to help others decide based on facts, not internet speculation. It is accepted that there have been drain plug failures, that required costly repairs. Why they failed was never clear, but blame was on excess material removal for the magnet, and the thought that the long drain plugs utilized different sized magnets. Ironically, the magnets are nearly the same diameter, differing by 0.080mm.
As for the bickering, like you, I pretty much disregard what I need to.
hi the gold plugs the engine drain plug the long one comes with a thick washer when I drain the oil do I put the new washer that is thin one over the large one or throw out the old thick aluminum washer>
richie spyder ![wink](images/smilies/icon_wink.gif)
