![Quote](images/misc/quote_icon.png) Originally Posted by acpd22
Well the tail lights that came with the Tag-along are gone. Replaced with LED's on custom made brackets. They are the low profile type. Pretty impressed with how bright they are. Haven't gotten around to figuring out why the marker lights don't work. If I had to guess it is the ground. ![shocked](images/smilies/shocked.gif)
Best to run a separate ground wire to all lights and not depend on the trailer frame. Also get rid of all the crimp connections, solder and weatherproof and put in a wire loom where exposed to the outside.
Current:
2016 Honda CTX700 DCT ABS (faring model)
Kip Moto SherpaX Cargo Trailer
Wife Has:
2014 Can-Am Spyder RT Limited
2016 Lees-ure Lite Camping Trailer
Previous:
2013 Can-Am Spyder RS SE5, zoom-zoom!
2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
![](https://badges.fuelly.com/images/smallsig-us/348915.png)
mine
I used Eye bolts to secure top box. Added CBR turn signal assemblies so as not to have to use a ratty converter. Cleaned and properly loaded the wheel bearings.
20170128_153739.jpgRS-S can not tell it is back there.
Tagalong Bearing Greasing
I purchased the tag a long trailer from HF last year and have made about 5 trips to Springfield MO from KC (Spyderfest, Spyders in the Ozarks plus other overnighters) and although I initially filled the bearings with grease through the zerks at the back of the hubs, I was wondering if packing grease into the hubs via bearing buddies (which I have recently purchased) will be enough to ensure the bearings are grease packed. I am hoping to not have to pull out the bearings to repack and would like to know if this method will suffice. I welcome any and all thoughts as to whether this will be sufficient for packing the bearings.
I love how the earth rotates around the sun ... it really makes my day!
Currently Own:
2019 F3 Limited - Vegas White (Dark Edition) - His
(Baja Ron bar/links-Short reach bars-Center footpegs-Tall boy screen-Flag holders-LED Skidplate-Spydercuffs-Ultimate seat-LED Headlights)
*** BLOWN MOTOR Apr 21 @3,800 miles, motor replaced by BRP Jun 5, 21 ***
2019 RT Limited - Phoenix Orange (Chrome) - Hers
(Baja Ron bar/links-Skidplate-Spydercuff-Comfort seat-LED Headlights)
Previously Owned:
2013 RT SE5 (Orbital Blue) *31,000 Miles* - His
2012 RT Ltd SE5 (Pink Full Body Wrap) *41,000 Miles* - Hers
2021 Ryker 900 (Black) Sport Windshield - Foam Grips - Solo Comfort Seat
![Quote](images/misc/quote_icon.png) Originally Posted by 2RTsGV
When I went to an automotive brake school MANY years ago they taught us to NEVER repack wheel bearing with our wheel bearing grease packer without thoroughly cleaning out the old grease...BECAUSE...
There are many different types of grease, lithium, calcium, sodium & some others...Most are NOT compatible with each other...Its like trying to put two positive ends of a magnet together...
So in my opinion and what I did on my HF trailer, was to remove the bearings, clean and inspect all bearings and pack with my grease in my bearing packer...Then at the beginning of the riding season I put several pumps of grease in the fittings on the back of the hubs and "ride on"
I use bearing buddies on all my other trailers that do not have zerk fittings...
larryd
I used to always clean wheel bearings with kerosene before repacking.
Went up...
Just looked at the website, they are showing $499.00 now. Holy cow they went up.
![Quote](images/misc/quote_icon.png) Originally Posted by arsquatch
They will be on sale again soon, just watch for it.
Current:
Wife Has:
Previous:
![Quote](images/misc/quote_icon.png) Originally Posted by retread
My Tag a Long had Scotch Locks for the splices on the wiring. I had to go through it and solder and heat shrink all of them to get rid of the shorts to ground. Also changed over to LED lights and 12 inch wheels. I've been using it for 5 years now, works great! john
I got tired of the harsh ride, so went with 10" wheels and oversized tires that can handle 20 psi and thus ride softer. Plus, I think it looks cool and if I ever need to ride through a swamp, the tires can handle it!
2014 RTL Platinum
![](signaturepics/sigpic20671_7.gif)
Trailer
If I were still traveling like I used to, I get a Leesure Lite Camper. I don’t enjoy tents anymore. This camper is almost a one finger set up & fold up. Can Am should make a camper trailer.
![Quote](images/misc/quote_icon.png) Originally Posted by moogully
This is a thread about cargo trailers. BRP is not going to build a tent trailer but there are several other companies that do.
2014 RTL Platinum
![Quote](images/misc/quote_icon.png) Originally Posted by UtahPete
Can you list the part numbers for the rims and tires you ordered for it? I assume also from Harbor Freight?
Thanks,
Bob
I just did a search on Harbor Freight's website and searched for trailers, utility trailers and even boat trailers. No results for anything other than trailer accessories. Wonder if they've quit selling trailers altogether?
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
![Quote](images/misc/quote_icon.png) Originally Posted by BoilerAnimal
Checked at my Harbor Freight , all sales have been suspended due to trailer not meeting DOT standards, there was a sign in the store.
![](signaturepics/sigpic20034_9.gif)
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
Kind of surprised that it hadn't happened before now, at least with some of them.
2013 RT-S SE 5
![Quote](images/misc/quote_icon.png) Originally Posted by finless
Can you list the part numbers for the rims and tires you ordered for it? I assume also from Harbor Freight? Thanks,Bob
You're going to love this; they are Kenda tires. I got them mounted on rims from eTrailer; https://www.etrailer.com/Tires_and_W...a/AM3H330.html
I chose them for their low load rating but high speed rating. They are wider than I expected and it took some work to get them to fit on the trailer without rubbing the frame (basically I used 1/2" washers as spacers behind the lug nuts).
The original fenders fit; I made standoffs from 1/4" aluminum tubing and longer bolts to mount them to the existing brackets.
At first, I thought I'd made a horrible mistake in ordering these, but now I've got them mounted I think they look great. I run them at 20# and they do provide a softer ride without much rolling resistance.
2014 RTL Platinum
