Results 1 to 15 of 15
    Apr 2018
    Corpus Christi Texas
    Default Vibration in handles
    Yesterday, I did about 400 miles with some friends of mine. I noticed a feint vibration on the handles when I reach about 71 MPH. It stays there until 76 MPH than goes away. It was not the road condition. Did that on any road even perfectly paved highway. The vehicle did not pull either way, just straight. Checked the tire pressure and all have the correct pressure. The bike is about 2 weeks old. So basically, it does that at a specific speed. Should I be concerned? I m due for the first service next week.
    That is a harmonic vibration coming from the drive-belt...
    Contact Doc Humphreys, and he can cure it for you!
    https://www.roadsterrenovations.info/
    United States
    That is a typical symptom of a belt vibrating. We have a pretty neat fix for that and it happens to be on sale. Here is a link for the RT:
    https://www.ebay.com/itm/12306187359...84.m1555.l2649
    Apr 2017
    North Central Florida
    Quote Originally Posted by mbenazeraf View Post
    You probably should not be too concerned......unless it bothers you enough that you "can't live with it".....because it probably is caused by drive belt vibration, which is pretty common.
    You definitely should mention it at your service appointment because it could be something else or the tension on the belt might not be right.
    If it persists after that, there are idler/tensioner kits available from a couple of sources to "fix" the problem.
    Several threads about that exist on here.
    I would think that a search for "belt" or "vibration" would find them.
    Dec 2015
    Oakley Utah
    That is a perfectly normal and harmless harmonic vibration from the drive belt. Nothing to be concerned about.
    2014 RTL Platinum
    Apr 2018
    I will bring it up to the dealer but it's a shame that we have to spend more money for an after market kit to correct something that BRP should have done before putting those bikes out.
    Dec 2015
    Oakley Utah
    There's nothing to 'correct'. It's normal for a belt drive and doesn't affect the performance any.
    You should be aware that the dealer will want to install the OEM vibration damper, which is not as good as the aftermarket ones.
    2014 RTL Platinum
    Doc's dual-bearing setup is vastly superior!
    Apr 2017
    +1
    Active Member Ryan12's Avatar
    Apr 2017
    Wichita, Kansas
    Default Absorbers
    I don't remember where I got them but I bought weights that go on the handle bar tips that is supposed to help with the vibration.
    wisconsin
    This may not have anything to do with your "faint vibration" issue, but on our '14 I had a faint vibration in my handle bars at anything above 50mph. What I found was a blemish/bubble on the inside sidewall of the rt. front tire (factory Kenda)and it would put my hands to sleep. You could barely see this blemish while riding down the road. The wheel would run true and you would look at the tire sidewall and it had a "bump" on it. Dealer would not replace it, so I lived with it until they wore out. I have none of the "vibrations" at speed that some people have unless I lugged the motor(short shifted) it, and then it would be barely noticeable. When I replaced the front tires all was good. Don't know if this will help you out, but maybe something else to look for. Mac
    Active Member Rohaianan's Avatar
    Jun 2010
    NY
    I saw this other dampener. Has anyone heard heard good, or bad on this one?
    https://www.slingmods.com/can-am-spy...tras?vehicle=1
    2015 White Can AM Spyder RTL
    2015 Black Harley Davidson Road Glide
    1998 Buell S3 Thunderbolt
    2012 Honda NC700XD
    Quote Originally Posted by Ryan12 View Post
    Those were popular in 2008/09. I had them on both my GS and RS. They helped.
    May 2017
    Adelaide Australia
    Quote Originally Posted by Bigmo View Post
    I had a similar problem with my F3LTD. I then found that my front tyres each had a "flat spot" of up to 3mm, which made the not evenly "round". I replaced the Kendas with car tyres, and problem solved. Running as smooth as.
    2016 F3Ltd , Red
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by Rohaianan View Post
    Doc's is better for less money. I would go for it if the vibration is bothersome.
