Missing License Plate Light cover
This cover was missing this morning from my 2008...anyone have an idea where I can get a replacement...it must have vibrated loose and fallen out on a ride recently
From the Lighting System parts diagram at this link,
https://can-am.brp.com/spyder/shop/f...ts-iframe.html, it looks to me like you need the License Light Assembly, PN 710001291, $49.99. It looks like the lens itself is not available as an individual part. Perhaps a dealer or Cheap Cycle Parts can help with just the lens.
With all the missing ones from F3's something should be available, question is: Did it vibrate off or, Did you back into something??![Lecturef Smilie](images/smilies/lecturef_smilie.gif)
![Roflblack](images/smilies/roflblack.gif)
Hope you you do find one, or something image.jpghttps://www.ebay.com/itm/LED-License-Plate-Mount-Bracket-with-Brake-Tail-Turn-Signal-Light-for-MOTORCYCLE-/132367251998
I had the same problem as you when I had my '08 RS. Here's what I replaced it with and worked fantastic, plus the light shows through the red (unlike BRP's). Never had another issue.
https://www.customdynamics.com/doubl...spyder?cat=168
Tail Light Lens
1+ on the Custom Dynamics Lens. Great illumination and less costly than OEM.
I have one on my ST. Secure it with RTV or Lock-Tite
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
![](https://www.spyderlovers.com/forums/maps/map.png?states=CO.NV.HI.NM.UT.WY.IA.MN.IL.IN.OH.PA.NY.NE.CA.OR.WA.MD.VA.WV.KY.MO.MI.SD)
![Quote](images/misc/quote_icon.png) Originally Posted by sockeye342
Thank you, this will work great ![thumbup](images/smilies/thumbup.gif)
So the replacement looks good, but does not come with the screw...Any ideas on size???...Thanks for saving me some time.
Went & pulled mine to see IMG_8106.jpg short sheetmetal screw, have to get sized at hardware store. #8X3/8 commonly just a #8 (standard panhead phillips)
Reason: (...)
