Results 1 to 16 of 16
    Jul 2016
    Huntsville Ontario
    Default Removing RT Antenna
    I am working on installing the BRP arm rests on our 2016 RT Limited.
    I’m not sure how to remove the antenna.
    Do I just remove the bolt and tiny nut shown in the photo or is there more to it?
    Thanks for your advise......brian
    2016 RT Limited SE6
    Default ANTENNEA REMOVAL
    Quote Originally Posted by BrianO View Post
    In that pic I don't see the antennae ....where did it go ..... most folks slide a 7mm deep socket over the antennae ( remove boot first ) then hold the socket with a vise grip pliers and un-screw it ....... it may not come out easily BRP uses the largest amount of lok-tite in the known Universe ..................Mike
    Jul 2016
    Huntsville Ontario
    Default More photos
    Here are some more photos.
    When I removed the boot, it looks like either a square nut or the square body of the antenna body....not sure which.
    2016 RT Limited SE6
    Jul 2013
    Vestaburg Michigan
    Follow Mike’s advise, be careful when removing and reinstall plastic painted cover it is a pain. Poor design. If you break any of the plastic hooks, you can repair with expoxy plastic glue. Been there 😩
    The 7mm socket trick doesn't work on the new "Shorty" antennas.
    But Lamont posted the most excellent video about it!
    You just have to find it...
    I found this in a two year-old thread:
    SPYDER RT:
    1. REMOVE THE OEM ANTENNA BY FIRST PULLING UP ON THE RUBBER BOOT AT THE BASE OF THE ANTENNA.
    2. USING A SMALL LOCKING PLIERS GRIP THE BOTTOM BRASS PIECE ON THE ANTENNA AND TURN LEFT TO REMOVE.
    3. CLEAN THE FLAT SURFACE AROUND THE THREADED HOLE WITH A CLEAN RAG AND RUBBING ALCOHOL AND LET DRY. SEE FIG. 1.
    4. TAKE THE NEW RUBBER GROMMET FROM THE PACKAGE AND PUSH IT INTO THE HOLE ON THE BODY PANEL AS SHOWN IN FIG. 2.
    5. REMOVE THE SET SCREW FROM THE PACKAGE AND CLEAN THE THREADS WITH RUBBING ALCOHOL. LET DRY.
    6. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE THREAD NEAR THE END OPPOSITE OF THE HEX SOCKET.
    7. INSTALL THE SET SCREW INTO THE ANTENNA MAST AND TIGHTEN WITH A 3MM ALLEN WRENCH. SEE FIG. 3.
    8. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE EXPOSED THREADS OF THE SET SCREW.
    9. CAREFULLY INSERT THE MAST THROUGH THE HOLE IN THE GROMMET AND THREAD IT INTO THE THREADS IN THE SPYDER. SEE FIG. 4. HAND TIGHTEN.
    10. YOU MAY NEED TO SLIGHTLY ROTATE THE GROMMET AS YOU ALIGN THE SET SCREW WITH THE THREADS IN THE SPYDER.
    Default This issue
    What you can't see is the large metal block that the Antennae is screwed into .... Don't un-do those bolts/nuts because the metal piece won't fit thru the antennae hole...... If the antennae is after market ( ie shorty ) you will have to separate the two plastic parts and as stated be very careful ........... What exactly are you trying to accomplish in this Thread subject .....knowledge is power and a good way to get better answers ........ Mike
    Jul 2016
    Huntsville Ontario
    I am installing the new BRP arm rests. I finished the left, now have to do the right side which as the antennae. The antennae is the original short one which came in my bike (2016 RT)
    I needto remove it so I can slide off the tupperware from the speaker pod.
    .....brian
    2016 RT Limited SE6
    Jul 2016
    Huntsville Ontario
    SPYDER RT:
    There is no brass piece at the bottom of the antenna. After removing the boot, I see the corigated rubber at the base of the antennae goes right down to the brass block. That corrugated rubber doesnt seem to move at all.
    Since my objective is to remove the Tupperware from the speaker pod, I a, thinking about removing the bold which holds the brass mounting block. Hopefully this will let me move the antennae around enough so I can remove the Tupperware.
    were you able to find Lamonster’s video?.....brian
    2016 RT Limited SE6
    Vermont
    Bob,
    I used a 7mm deep socket wrench to replace my long antenna ( which I snapped off at the gold base) with a short antenna. Look @ "My Albums". I did not scratch the paint. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    I have a 2014RTS-SE6 and I replaced my original ( long antenna) to a short antenna.
    Here is a picture:
    Boot/ Short Antenna
    Sorry no pictures of inside where gold base is.
    I used a 7mm deep socket wrench. I did this on my own.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jul 2016
    Huntsville Ontario
    Default Soultiion Found!
    I discovered I could leave the antennae attached to the brass mounting block, and detach the mounting block from the speaker housing. This allowed the antennae to flop around enough to get the Tupperware off.
    thank you everyone for your suggestions!
    .....brian
    2016 RT Limited SE6
    Sep 2014
    USA
    If it doesn't come off use a hair dryer to warm up the area. They may have used Loctite on the threads.
    .....brian
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    turn the antenna to the right like your tightening it and pull up at the same time. It's on a spring that tightens when you turn left. Lamonster garage has a video on it.
    Quote Originally Posted by nightcruiser View Post
    Do you realize you just posted to a three year old thread wherein the OP said how he solved the problem?
