Results 1 to 10 of 10
Thread: Cat Delete
    Apr 2017
    corpus christi, texas
    Default Cat Delete
    What are some helpful hints for mounting the cat-delete pipe springs, this is on late model RT? Already have done this before with the standard spring hook for motorcycles. There has to be an easier method than brute force.....LOL
    Jul 2016
    Arizona
    Default Springs
    I just used needle nose visegrips.. Works great..
    Houston
    I have done quite a few of these and use the Yamaha branded spring hook.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2015
    Lodi WI
    Default right angle needle nose
    I got a set of 14" very long needle nose pliers from harbor freight. One of them was a RIGHT angle at the end. I was able to hook the spring and able to pull straight back. A lot more pulling power. As for the other long needle nose I can't tell you how many times I used one or the other to retrieve a dropped screw from deep inside where fingers and smaller pliers cant reach.
    tip: lift the rear of the cat delete and do the top spring first.
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    This made the job a 15 minute easy project:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Northern Kalifornia
    Default If there is the will there is a way.......
    I used a HF spring hook but someone else on here used a length of parachute cord. They tied one end to the spring and the other to their foot then pulled the spring and hooked it up.
    Default A TOOL I MADE
    Quote Originally Posted by donrokon View Post
    ....I had difficulty also ..... I made a tool from flat stock with a nail bent into a hook near the end ..... I used it as a lever to get the springs off & on ....... I can send pics to a smart phone ..... PM me if you want them ( with your # ) .... Mike
    Nov 2015
    Myerstown, Pennsylvania
    http://www.spyderlovers.com/forums/s...04#post1330904
    Take a look at post #29. I used a good dog leash for a small dog. Worked great!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Northern Kalifornia
    Quote Originally Posted by SteveLaoyster View Post
    See #5 also. SpyderAnn and hubby have done a bunch of them without losing too much skin.
    Nov 2013
    Oro Valley Arizona
    My Cat was really easy to remove and install. Scientific term "Kitty Deletes" was done by Lamont. Both of
    them.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
