Page 17 of 22 FirstFirst ... 7131415161718192021 ... LastLast
Results 401 to 425 of 541
  1. #401
    Member Madmartigan's Avatar
    May 2016
    Chattanooga Tennessee
    Definitely check out the belt. I'm sure others here will have the same issue. As for BRP they know there is a problem with the sprockets. BRP authorized the repair no questions asked. I'm sure as this continues to happen more and more they will have to change the metal that the sprockets are made of and have a massive recall. This is a safety issue. Imagine if you are making a left at an intersection and as you start to accelerate the sprocket goes. You are stuck in the middle of the intersection and are now a sitting duck for the oncoming traffic. That could be deadly.
    I used to think it was a terrible thing that life was so unfair. Then I thought, "what if life was fair, and all of the terrible things that happen to us came because we really deserved them?" Now I take great comfort in the general unfairness and hostility of the universe.
  2. #402
    United States
    Quote Originally Posted by Madmartigan View Post
    That is exactly how this thread started last year in Maggie Valley. Ryder was stopped at a light on a 4 lane road and started to take off and the sprocket grenaded. He is extremely lucky he wasn't run down.
  3. #403
    Dec 2009
    West Oz
    Call me a sceptic (or anything else you like) but this will not eventuate in a recall - a Service Bulletin maybe, but it's too trivial in BRP's scheme of things to do THAT.
  4. #404
    Feb 2013
    Victoria Texas 77901
    Default 2017 RTS
    I WAS ON A TRIP WITH FRIEND, SPYDER WINTER RIDE-IN TOMBSTONE AZ. JAN 2018 FRONT PULLEY FAIL I WAS 15 MILE FROM A DEALER HAD 18500 MILE AT TIME OF FAILLYER.
  5. #405
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Has this been reported to NHSTA? Too many failures listed, how many does it take for a recall?
    2016 F3L , Big Bike Parts Black
  6. #406
    Apr 2012
    Northglenn Colorado
    I just had my 3k service on my 2017 F3T. Told the mechanic I wanted it checked out. He took a picture and no rust. I live in Colorado, a very dry state. May have something to do with it.
  7. #407
    Oct 2010
    Wisconsin Rapids
    What would be the downside of leaving the inspection cover off? You could look at the sprocket before every ride.
  8. #408
    Houston
    Quote Originally Posted by Machinegunner View Post
    Not much but do not wear shoes with laces....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  9. #409
    United States
    Very good point! And if you happened to shift the toe of the boot into the rear of the sprocket!! Think I'll keep mine on.
    That could get ugly really, really quick!!
  10. #410
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Quote Originally Posted by Roadster Renovations View Post
    Knowing you Doc as I do, I reckon you could either make a transparent cover as a replacement for the OEM cover or somehow make an inspection window in the existing cover to make it easier for riders to do an inspection from time to time
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
  11. #411
    Active Member EricP's Avatar
    Dec 2017
    Atlanta, GA
    Default Cheap Endoscope Would Do the Trick...
    Couldn't one just use some sort of endoscope to snake in and look (and save the work of removing the cover)?
    Something like this could do the trick: http://a.co/iTndUjz
    Boris - The Spyder
    Monster FI Stage 1, Elka Stage 2 F&R, BajaRon Swaybar, Lamonster Links,
    Akrapovic Straight Shot Silencer, Madstad Windshield, Cannonball Seats, Driver Backrest, Driver Footboards,
    15" Fat 6 Chrome Wheels, LED Headlights, LED Fog Lights, Chrome Handlebars, Chrome Frame Caps, Front Cargo 12v Power Outlet Kit,
    Ram Phone Mount, USB Power (Handlebars), Full-Size Brake Pedal, Lamonster 3rd Peg w/ Kuryakyn Trident Large ISO-Pegs, Cross-Country Detachable Saddlebags
    2015 F3 , Stock I use the Extended Brake Pedal Silver with black stripes and Can-Am Red/Orange accents
  12. #412
    United States
    Quote Originally Posted by eddieshep999 View Post
    Knowing you Doc as I do you, I reckon you could either make a transparent cover as a replacement for the OEM cover or somehow make an inspection window in the existing cover to make it easier for riders to do an inspection from time to time
    In the works..........
    Oppsss, well now that cat is out......that's OK we'll still beat 'em on price!
  13. #413
    Houston
    Quote Originally Posted by EricP View Post
    We do. When bikes are in for oil changes we do the sprocket inspection from below and rear of the drive sprocket. We are under the bike anyway when its on the lift. You can see enough of the pulley face to determine if there is red dust by lighting up the pulley with a flash light and looking from the rear.
  14. #414
    Florida
    I ain't using no endoscope. Those are the tools of proctologists to check your endo
  15. #415
    Dec 2017
    Atlanta, GA
    Quote Originally Posted by Capt. Bob View Post
    Boris - The Spyder
  16. #416
    May 2009
    Connecticut
    It takes a Minute or two to take the 3 Screws off the cover and look? That way you get the Full Picture.
    Sea Doo GTI-SE 90 Jet Ski!!
  17. #417
    Oct 2010
    Wisconsin Rapids
    I removed the sprocket cover. Then removed the insulation piece behind it. Drilled a 1/2 inch hole in the cover and installed faucet hole cover. Now I can check the sprocket in just seconds. Doesn't look wrong on the bike either. Don't even notice the change.
  18. #418
    Jul 2017
    sarasota, fl
    good idea and sounds easy enough
    do you notice an increase in noise with the insulation piece removed?
  19. #419
    Glasgow, Scotland
    Pictures?
  20. #420
    Oct 2010
    Wisconsin Rapids
    I knew some one would ask for pictures. I didn't take any, but simple to visualize. Just take the faucet hole cover and locate a smooth spot on the cover and drill with a hole saw. Only cost about $3 for the hole cover. Haven't ridden it yet, hasn't rained enough to wash the salt off yet.
  21. #421
    Glasgow, Scotland
    Trouble is, I don't know what a faucet hole cover looks like..
  22. #422
    Oct 2010
    Wisconsin Rapids
    Buy one at a plumbing shop or home improvement store. They are used to cover a hole for the spray hose in a sink if it is not used. They are held in with little fingers on their back. Go in and come out easily.
  23. #423
    Jul 2017
    sarasota, fl
    here's a link to one at Home Depot
    https://www.homedepot.com/p/Elkay-Ki...125R/202266945
    still wondering If there is a noticeable noise increase after removal of the insulation piece.
  24. #424
    Glasgow, Scotland
    Quote Originally Posted by ofdave View Post
    Aha! I'll see if we can get such a thing over here. Thanks guys.
  25. #425
    United States
    Sounds like you are on to something. It will be interesting how it works over time with the vibration from the byke and the road.
