Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 78
  1. #51
    Default TIRE DEALER !!!!!!
    Quote Originally Posted by BoilerAnimal View Post
    http://us.coopertire.com/Tires/Passe...a-Touring.aspx
    Under "Features and benefits", the third bullet says that they are asymmetrical. Goes for both CS5 tires. I was going to put one on my Spyder and the tire dealer advised against it.
    " Tire Dealer " !!!, I'll bet almost all TIRE DEALERS will tell you not to put a CAR tire on a MOTORCYCLE ..... if you go to Discount Tire, to buy a tire and tell them you are putting ANY of their tires on your Spyder ..... THEY WON'T SELL YOU A TIRE !!!!!!!!! ........... as I stated earlier " if it upsets you , don't use it " ...... Mike Now I'm curious about the Asymmetrical tire thing.... there are three types of tread - directional - symmetrical and asymmetrical ..... Why exactly are you concerned about using an asymmetrical tread on the REAR of a Spyder ?..... What do you think will occur differently from the other TWO ? .... I think a lot of folks here would like to know ... Mike
  2. #52
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    http://barrystiretech.com/directiona...icaltires.html
    After doing some reading I don't think there would be any problems using an asymmetrical tire. The dealer I took it to didn't have any problems with mounting it on my rim. He asked what it was for and I told him. I showed him one of the tire threads on here and he said OK. He couldn't spin balance it though so I took it to a motorcycle shop to have that done. I was running about 21 PSI on it before it had to go in the shop. When I get it back, I'll try 18.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
  3. #53
    Default ASYMMETRICAL TIRE
    .... in your post # 50 quote " the tire dealer advised against it " ? ? ? ... BUT HE had no issue with mounting it ............... soooooooooooooo did you discover that asymmetrical tread means little or nothing as far as one rear tire on the Spyder goes ????? ..... this matters because ....." GaryTheBadger " is putting this tire on His RT ................... Mike
  4. #54
    May 2016
    He wouldn't mount it is what I should have said. He advised against me having it done elsewhere. He had no problem with a car tire. He said the tire that was on it was just a car tire but a poor one. I ended up with a Yokohama. I put about 2200 miles on it so far and love it!
    Added: see post 16.
    2013 RT-S SE 5
  5. #55
    Conventional motorcycle tires generally aren't asymmetrical simply because the 2 wheeled motorcycle they are most often fitted to needs to corner both ways & therefore needs both sides of the (rounded) tire to perform much the same way or you'll get handling behaviour differences depending upon which way you lean.... and many tire dealers simply can't get beyond that idea!! But to put it bluntly, that's simply not the case with our Spyders & the car tires they run because they DON'T lean to steer, especially if you are talking about a tire fitted to the rear!! The traction & 'thrust' provided by our rear (drive) tire has been designed specifically to apply along the long axis of the Spyder, straight between the two front (steer) wheels, so running asymmetrical tires will have an extremely tiny impact (if ANY at all!) on how our Spyders behave!
    In fact, probably the most significant impact they might have is likely to be an IMPROVED level of traction & therefore thrust available across a wider range of road surfaces & weather conditions due to the multi-condition/surface design of the asymmetrical tire!! They have tread sections that have been designed to provide higher levels of traction in each of wet or dry conditions - nb, that's higher levels of traction than you'll ever get from a tread designed as a compromise that'll work sorta OK in all conditions or even one designed to work best in just one condition. You could probably get better traction in the wet by fitting a specially designed wet weather performance tire, but it'll probably suffer in the dry; you could probably get better traction in the dry by fitting a specially designed dry weather performance tire, but it'll very likely be crap in the wet; OR if you want something better than the usual compromise 'all weather tires' that are available, you could fit an asymmetric tire that has tread sections which have been designed to work at least as well as BOTH those specialist tires in their respective conditions!!
    Bear in mind that just about ALL car tires have some degree of performance bias designed into them anyway, ie, they are often 'Sport/Touring tires that excel in the wet' or 'Ultra Performance tires with un-paralleled dry weather traction', so fitting asymmetric tires is just taking that a step further! And because our Spyders have been very carefully designed to deliver thrust from the driving rear tire thru the centre-line of the front (steer) wheels, anything that improves drive wheel traction under any or all weather conditions is likely to improve overall performance!! You just hafta try to ensure you are running any tire at an appropriate pressure to let the said tire support the load AND STILL achieve the necessary temperature increase (& therefore pressure increase) to allow its tread to reach its optimum operating temps & traction, but without going so low in pressure that it adversely impacts handling or increases the temperature too much!
    So why should you hesitate to select a performance tire that suits your driving needs, regardless of it being symmetrical or asymmetrical?
  6. #56
    Phoenix
    Default tire pressure
    Quote Originally Posted by jtoro1 View Post
    I have 17k on my Yokohama s drive maybe it will go 5k more not bad, I have another on order
    what tire pressure are you running on yoko rear?
  7. #57
    Apr 2016
    Minnesota
    Default Run Flat Tires
    Are any of the tires mentioned in this thread run-flats? I ran a run-flat tire on my Goldwing and was happy with the performance and mileage I got with it.
  8. #58
    Default RUN FLATS
    Quote Originally Posted by gofast4 View Post
    I did some research on this awhile back and tire sizes were an issue ...... plus from what I learned I wouldn't get them no matter the sizing issue...... Mike
  9. #59
    Jan 2009
    Northwest Arkansas
    Is anyone using the Vee Rubber VTR-350 Arachnid tire? It's marketed as specifically designed for the Spyder. I am most interested in mileage and a symmetrical design across the tire. No rain use.
    https://www.bikebandit.com/tires-tub...SABEgK5BvD_BwE
    2015 F3 SE6 , White - The fastest color!
  10. #60
    Jan 2009
    Northwest Arkansas
    NEVERMIND...I found some posts about this tire from years ago. It's still available, but apparently no better then OEM Kenda.
  11. #61
    Default The Arachnid tire
    Quote Originally Posted by GaryTheBadger View Post
    98% of the people on this Forum have said it was no better than the Kenda and usually worse. They are a Clone of the Kenda , so it's also much weaker than any Car tire........Also tires that were designed and produced years ago, can't compete with the newer designs of today .....Mike
  12. #62
    Feb 2012
    Spring City,Utah
    Hi Mike
    What did you learn that you didn't like about runflats on a Spyder (or possibly any vehicle)?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  13. #63
    Quote Originally Posted by marty1096 View Post
    That's an entirely new kettle of fish; that needs frying...
  14. #64
    Default RUN-FLAT TIRES
    Hi Mike
    ...... Sorry I did that research a couple of years ago and I just can't remember the details ...... but I do remember that they don't come in our sizes and they are UBER expensive ........ Mike
  15. #65
    Aug 2017
    Wisconsin
    I have an 2017 F-3 Ltd that’ll need a back tire soon. I like the looks of the Altimax, but I wonder whether it’ll fit. The clearance between the mud flap and the OEM Kendra 225/50-15 is exactly one inch. The 215/60-15 Altimax, being taller, reduces that clearance to just over 3/8”. That’s pretty tight. Has anybody tried that Altimax on this exact model Spyder?
  16. #66
    Aug 2015
    NW Iowa
    Default Where did my previous reply to this thread go?
    I had a reply to this thread a few days ago about my new rear tire being Yokohama S Drive and it just disappeared. So did the specific reply to it. Just wondered where it went?
    Now
    2021 Sea2Sky
    Former
    2015 F3-S
  17. #67
    Feb 2013
    Edinburg, TX
    Quote Originally Posted by Morturf View Post
    That was on a different thread, about a Michelin tire, started by BLUEKNIGHT911. Yup, that thread is now gone... I don't know what happened to it.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
  18. #68
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Jambo Creek View Post
    We have the Altimax on our 2016 F3L. 215/60/15 fits fine. 8,500 miles so far.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  19. #69
    Aug 2017
    Wisconsin
    Default Thanks
    I’ve noticed a lot of the tire replacement discussion addresses traction issues. I think the tread pattern on the Altimax tire might shed water better than the Kumho because it has more channels, but I was concerned about mudflap clearance. I appreciate reassurance from somebody with firsthand experience. Thanks.
  20. #70
    Houston
    We have had trouble on the RT with clearance on bikes that came in with the 215-60-15 General, and others. Its one of the reasons we standardized on and stock the Yoko 205/55/15 as its an exact match so no clearance issues.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  21. #71
    Default MISSING TIRE THREAD
    Quote Originally Posted by missouriboy View Post
    I started that Thread and removed it because like a lot of Threads on this Forum it became a discussion about something else..........IMHO if people want to discuss something else maybe they should start another TREAD !!!!! .................Mike
  22. #72
    Jan 2009
    Northwest Arkansas
    Based on the recommendation of PitBull Powersports and reading many positive online reviews, I'm going for the Kumho Ecsta AST for the rear of my F3. Bonus...it's symmetrical across the tread
  23. #73
    Houston
    If you want to do burn outs, it does break loose easier but its also not very good in the rain. We have replaced a number of those for these two reasons alone.
  24. #74
    Aug 2015
    NW Iowa
    Ridden 70 miles on the new combo of continental contact pro up front and Yokohama S drive rear. I have to say it is a night and day difference in that little amount of time. Not too mention the Baja Ron bar. Made the machine the way it always should have been! Thanks for the feedback on the other post!
    Now
    2021 Sea2Sky
    Former
    2015 F3-S
  25. #75
    Jan 2009
    Northwest Arkansas
    JCTHORNE, I never ride in the rain, so it shouldn't be a problem.
