Results 1 to 24 of 24
    May 2016
    Ontario, Canada
    Default RT Dash Accessory Bar.
    I hope someone can point me in the right direction. A long while back I remember seeing someone was selling a chrome or stainless bar that attaches via those two bolts on top of the RT dash. I believe it had spyder cut out in it. Can someone remember who/company that was. Been looking ---- but no luck.
    Thank's in advance
    Johnny.
    Oct 2011
    Jacksonville,Ar
    you will like the one from JT
    15 rt , yes Black
    To be honest: TricLED also sells one...
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default Dash mount
    Quote Originally Posted by johnny canuck View Post
    Thank's in advance
    Johnny.
    I think this is what you are looking for. This is the one I have.
    http://store.valueaccessories.net/Sp...ompatible.aspx
    Mar 2015
    forrest above Reno, Nv
    Thank's in advance
    Johnny.
    With the sun behind you the reflection/ glare might be a bit much. The ones you can purchase above are flat black. I painted the aluminum one I made---- plane and simple----works perfect.
    Lew L
    2014 RTS , Circuit Yellow
    As much as I like "Shiny": I sure don't like the glare produced by reflected sunlight...
    Active Member Merlot2015's Avatar
    Honolulu & San Diego
    TricLED has a very nice black powder coated (aluminum) multi mount dash bracket.
    2015 RT-S Special Series BajaRons bar w/heim links, Spyderpops bumpskid, Lamonster's - Dual power plate w/gps swivel, NBV pegs, IPS lidlox & key cover, Spyder cuff w/holder, Perf cat-delete pipe w/ BC Thunder QQ baffle, Ultra brt LED fog & headlights. TricLED safety bundle & Wide Vu, Stebel horn, Akrapovic sport exhaust, Ultimate Croc inlay seat, BRP passenger armrests, BRP air scoop, ISCI handbrake, 23" vent windshield, Garmin 595 GPS w/Kradellock, Magic mirrors.
    Vermont
    Here is a picture of the RT Dash bar that I have :
    Dash bar mount 001.jpg Flat dash bar mount.
    I bought the above from JT Thornton I have a 2014RTS-SE6.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I have JT's, and have not had a problem with sun glare
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Jul 2017
    Massachusetts
    Default I ordered from TRICLED
    I ordered mine last week, had it by Friday, had it installed in less than 15 minutes on Saturday. Added a Ram Mount 3" extension along with a Ram Mount X-Grip for my phone.
    2017 Can-Am Spyder RT
    Quote Originally Posted by imfleck View Post
    Pictures please!
    Cambridge, Ontaio
    Spyderchrome also sells one, they are in Quebec. Less cost with exchange, shipping and fees.
    https://www.spyderchrome.net
    Faribault, MN
    TricLED's Dashbar with ram mounts,
    (Though the bar is hard to see.)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2017
    Massachusetts
    Default Here's how I've mounted mine
    Oct 2015
    Pleasant Garden, NC
    Default dash mount
    I bought one of these and installed it on my 2015 RT-S. Easy to install and love the way it looks. I have one problem that I figure can be solved. My ram arms will not tighten enough on the slick ram balls that came with the dash mount. As I drive the arm continues to slip until my GPS is bouncing on my dash. Anyone else experience this?
    Take a pair of Vise Grips, and wrap the teeth in a piece of denim...
    You'll be able to grab the knob, and give it a serious twist with that setup!
    I've lost ALL strength in my hands, and this trick works for me...
    Jul 2016
    Kamloops B.C.
    Make sure the balls don't have aluminium threads. I twisted 2 right off doing this.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nowhere
    JT’s dash mount here.
    I had attempted to use just Ram mounts to get my Zumo 550 up and over the dash but the long arm was an inch too short. JT’s Dash Mount adds a spacer that moved the Ram ball up enough that the Zumo plate misses the dash. Perfect.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    May 2013
    Sacrament0, CA
    Made mine from some aluminum plate I had as leftover. Painted it with black Plasti Dip.
    If I had to buy, it would have been JT's
    Jun 2017
    Crossville TN
    Default Power ?
    I am just wondering how everyone routes there phone charger cables etc. up to this dash mount. I have yet to take the plastic off for my first oil change. I was originally thinking of mounting my x grip on the hand grip but like this idea a lot better Thanks guys
    Dave
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Fire34 View Post
    Dave
    I ran the power cord for my GPS up through the swing arm slot for the windscreen. It has been there for 2 years, and no issues.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jun 2017
    Crossville TN
    Default Thanks
    That was what I was thinking but was afraid of the raising and lowering of the windscreen would hurt them Thanks again
    Dave
    Quote Originally Posted by bcer960 View Post
