Results 1 to 8 of 8
    Oct 2017
    N.E. Ohio, USA
    Default Back Rest on 2011 RT manual?
    Can I install a driver's back rest on my original 2011 RT seat. Or do I have to buy a more modern seat? Will any year RT seat fit my bike?
    Dec 2015
    Decorah, Ia.
    Quote Originally Posted by daz View Post
    Yes you can install back rest on 2011 RT. I used a Show Chrome brand I believe, it was not hard to do at all. May need to remove if carry a larger passenger. Will be uncomfortable for both if leave it on, only one bolt to remove if needed.
    And Yes, any year RT seat will fit your 2011 RT - Just make sure you mask or cover the 'bottomless pit' holes alongside/under the hinges when you are fitting/removing the bolts on the rear hinges.....
    Anything falling in those requires you to lift your Spyder overhead, turning it upside down, and shake it vigourously in order to stand ANY chance of ever getting it back out!!
    Danbury Connecticut
    Yes, gou can purchase a 2014 or later BRP model seat and install a BRP backrest.
    Are you aware that you can also install third party backrests and mount them to your original seat ? Often these backrests cost less than tge BRP one, and you don"t have to buy a new seat.
    My best recommendation would be a Utopia backrest.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Apr 2013
    Somersworth, NH
    Default After market back rest
    Check out http://www.utpr.com
    I had a removable back rest on my 2011. It just pulled straight out; very convenient.
    Good luck
    Lin
    2016 RT-S Special , 2 tone black
    Oct 2017
    N.E. Ohio, USA
    Thanks. I will go Utopia!
    Heed this warning: Peter is NOT lying!
    Nov 2012
    North Las Vegas, NV
    Here is a backrest you can add to your current seat. http://store.valueaccessories.net/Sm...mSpyderRT.aspx
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
