Results 1 to 21 of 21
    Active Member bobnaquin's Avatar
    Nov 2011
    St George UTah
    Default Help with Brp communication system
    My
    Use got 2017 Spyder RTS with gps, cb and entertainment system.
    I can’t communicate with my passenger. We have the Brp headsets. I have vox turned up all of the way. If I push the ptt switch we can communicate but aren’ t we broadcasting on cb at that point.?
    It seems like we should be able to activate the voice operated switch
    and talk just to each other.
    I am missing something and if you could get me up the learning curve I would
    Appreciate it.
    Apr 2012
    Columbus, Ohio
    Quote Originally Posted by bobnaquin View Post
    My
    I can’t communicate with my passenger. We have the Brp headsets. I have box turned up all of the way. If I push the ptt switch we can communicate but aren’ t we broadcasting on cb at that point.
    It seems like we should be able to voice operated switch
    H and talk just to each other.
    Appreciate it.
    Did you set it up for Vox?
    My
    Appreciate it.
    Download the manual here: http://instructions.brp.com/content/...mber=219400611
    About 2/3 of the way down are the instructions you're looking for.
    Nov 2011
    St George UTah
    Quote Originally Posted by R30SHIRE View Post
    After reading the manual given to me below I realized that I had VOX all the way up effectively turning it off. Thanks for your help.
    Nov 2011
    St George UTah
    Thank you. Thank you. THAT was exactly what I needed. Next drink is on me.
    Nov 2011
    St George UTah
    Default More issues with BRP communication system
    So I got the VOX to work. Thanks to those that helped
    N
    When I turn up the speaker volume all the way the speakers are painfully loud. At the same setting the audio, intercom and gps are barely discernible in the BRP headsets. This is withvolume at maximum
    Is there another volume control that controls headset volume. I have the one in the cb screen set to max. What little sound there is only comes through the left speaker in either passenger or driver headsets.
    Help.
    N
    Help.
    Go into the Preferences screen. There are some headset settings there. I don't recall right off hand what they all are but you can figure them out. You can turn speakers off there also. The owner's manual doesn't explain them at all.
    Nov 2011
    St George UTah
    I went there and tried them all. They have little impact. The volume in the headsets is so low it is hard to discern what the controls are doing. I am convinced there is a repair needed and will visit the dealer on Tuesday to see if they have any ideas
    Thanks for your help. I believe I just spent a lot of money for somethiing that could have been done with my $300 Sena headsets. After 10 years of owning Spyders, it is not the first time. The bike runs good so there is that.
    Cheers.
    Apr 2017
    North Central Florida
    Those things are tricky.
    It is possible that you now have the VOX set too far the OTHER way......and it is ON all the time, thereby muting the speaker output.
    I had a hell of a time getting mine right.......and I don't even have a second headset or a passenger.
    Just yesterday, I started out for a ride and the headset volume was WAY down.
    When I looked at the settings, a bunch of them had changed......and I did NOT do it. SIGH.
    Nov 2011
    St George UTah
    I am beginning to figure out that this thing has a mind of its own. I went out yesterday and I actually had to turn the volume DOWN on the intercom and radio. The right headset speaker is still out on the passenger and I have yet to hear anything over the cb although I have the squelch set pretty low.
    Apr 2017
    Check all of the cord connection points for the failing headset......including the one right AT the mounting point on the helmet.
    It was a long time before I realized that there WAS a removable connection right at the helmet.......and that is the one that I found loose the last time one side was dead.
    Terminology note:
    A low squelch setting lets all the noise through; a HIGH squelch setting lets almost nothing through.
    Nov 2011
    St George UTah
    Terminology note:
    I did. It was not fully inserted. Now both headset ear pieces work. Thank you.
    Apr 2017
    Glad I could help.
    Alas, I can't tell you what to do to keep the audio system from screwing with you occasionally.
    Nov 2011
    St George UTah
    Glad I could help.
    Do you have any idea what the fader controls do under the preferences ? How about the Headset Fr.? I feel I should be able to figure this out but thought I would get the benefit of you suffering through this.
    Jun 2017
    Crossville TN
    Default fader contrils
    they control the speaker volume from front to back if you fade to the rear etc. those speakers get more of-the volume
    Dave
    Sena and similar are looking better all the time. I am thinking I am going to avoid all the electronic gizmos.
    I am still liking my Rand McNally atlas. At three years old its getting a bit dog eared. Maybe time to update to 2018.
    Apr 2017
    Quote Originally Posted by Fire34 View Post
    Dave
    That is true of the "fader" controls.
    Not sure what the "headset fr" is.
    I got MUCH better information with the CB installation kit.
    Maybe I should scan and post them sometime.
    When I found a group of settings that worked, I stopped studying the details.
    But it's a bit easier when you don't use the rear headset.
    Nov 2011
    St George UTah
    It has been a long time since we chatted. I hope you are well.
    Go with Sena. I spent $3400 on a full up BRP communication system and I have serious buyers remorse. The only part that works somewhat well is the helmet to helmet intercom. I had that with the Sena system I took off of my helmets. The only difference is that now I have to be plugged into the bike to use the intercom which I did not need with the Sena.
    I ride with a group of Gold Wingers who use the CB. I have not tried it yet but I am not all that hopeful it will work very well.
    The radio is okay but I don't generally listen to radio. Above 70MPH the intercom noise shuts off the radio. I don't like the idea of broadcasting through the speakers which are incredibly loud.
    The GPS is okay. Not any better than the $150 one I had been using. I never worried about the $150 one getting stolen. Odd that there is now way to secure a $600 plus GPS to a bike.
    I have been at this point with other BRP stuff. I will find the right combination to make it work somewhat. I bought this thinking I would not have to work at it at all. Silly me.
    Nov 2011
    St George UTah
    I got the CB installation instructions from some kind soul on here. It does not cover the Headset FR. control. That is part of the preference screen under audio.
    My passenger does not hear any more or less than I do. I am not sure how that makes it more difficult. I will keep at it until it wears me down.
    It controls the ratio of volume in the headsets driver and passenger. Since I always ride solo I have mine set at 100% front.
    Nov 2011
    St George UTah
    I have 'discovered' I think, that the Headset FR is the radio volume control for the driver headset. More negative makes it less loud. By placing this to a more positive setting my headset got a lot louder.
