Results 1 to 25 of 40
    Greenville Tx
    Default Which is the best Belt Tensioner for an F3 LTD?
    Got a new F3 Limited a few days ago and found it to have a lot of vibration at highway speeds. I was looking on here and found basically 2 different styles, one applies tension to the upper side and the other to the lower side.
    now I'm confused, is the vibration coming from the upper side which is pulling or the lower side which has the slack?
    Mar 2016
    Highriver,ab.canada
    Default Belt damper
    Quote Originally Posted by AY4B View Post
    I put the the brp damper pulley which goes on the top , all vibration gone. Now saying that I am keeping a very close eye on pulley and bearing. I only have about 4000 Km on it so we will see.
    crossbow
    Two Words for you: Doc Humphreys!
    Greenville Tx
    That is the one I’m leaning to but was wondering why there are 2 different kinds. The Smooth Spyder says that it wont work with LDT’s because they can not bolt to the air controlled shock.
    Greenville Tx
    First i need to get the dealer to check to see if the tension is right. I did not have much vibration on my ST.
    Active Member Badco149's Avatar
    MERRIMACK
    I will be going on my second summer with the Smoothspyder tensioner. I have ZERO vibration and ZERO worries about the bearing wearing out. A little pricey but you get what you pay for. High quality. Very solid build.
    IMHO
    2016 Spyder F3 Limited Special Series
    May 2009
    Connecticut
    Right On- Get the tension Right Per the Dealer and you Should Not need a tensioner -
    Sea Doo GTI-SE 90 Jet Ski!!
    Aug 2013
    Northern California
    Have to agree no vibration at all here! You have to have it set up right!
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I have about 16,000 miles on a Smooth Spyder for my ‘16 F3L. It cured the vibration issue and is built like a tank.
    2016 F3L , Big Bike Parts Black
    Greenville Tx
    Quote Originally Posted by papanorm View Post
    Greenville Tx
    Its interesting that both Smooth Spyder and Roadster Renovations approach it from 2 different directions with the same results.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Sarge707 View Post
    If that was truly the case I doubt that BRP would have gone through the expense of making a tensioner.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Greenville Tx
    I wouldn't even consider a BRP tensioner after watching this video giving a comparison.
    United States
    Wow, been a while since I did THAT video! At the time of this being made, the BRP damper had just come out and there had been no failures at that point. Kind of neat that what I said proved out. Anyway, I have had many improvements since this video and I will try to list them all by their order so that there is no confusion.
    1. We changed the aluminum roller to nylon. On our initial testing on my Daytona we found that the aluminum scratched and transferred that lightly to the top of the belt. The nylon does not do that. As far as longevity, we replaced a roller the other day for a customer that had some noticeable wear. It could still have been used, but since I was servicing his unit we replaced it. He had 40,000 miles on it. The bearings were still perfect with no wear.
    2. We increased the diameter of the pivot spring as a few of them were failing. This also happened to the BRP units also.
    3. We determined that since there was very minimal adjustment on the BRP kits, we would be unable to offer just the arm. They were not getting into a good enough position. Our brackets are slotted and allow for more adjustment.
    4. We began to find that the BRP units' pivot point was seizing up and locking up away from the belt. We added a outer seal to keep grit from getting into the pivot. We also added a grease fitting to make maintenance easier.
    5. We included an adjustment block that allowed perfect alignment with the belt.
    These changes have been in place since about May last year. We have not found a need to do any more changes. We still warranty everything for 1 year and the roller and bearings for 2 years.
    https://www.roadsterrenovations.info/products
    Greenville Tx
    Quote Originally Posted by Roadster Renovations View Post
    Thanks Doc,
    I could not find a more recent video that did a comparison as well as that one did. I did however see that you had made some improvements. I just ordered one, Thanks.
    United States
    Thanks Doc,
    Saw that! It will go out tomorrow! Thank You!
    Greenville Tx
    One more thing to scratch off my long list. It was near the top after the ride I went on Sunday.
    Probablly the next thing Ill get is the Baha Ron Swaybar, Then a Lamonster Drivers backrest.
    Greenville Tx
    All in all, Im really loving my new F3 limited!!
    Bossier LoUiSiAna
    So you mentioned seeing oil spot on the ST is that all you needed for excuse for F3?
    Greenville Tx
    That was an excellent excuse I would say!!
    Aug 2017
    Wisconsin
    I have a 2017 F-3 LTD, now with 8,000 miles on it. It had the high speed vibration that drives new owners nuts, so about 4,000 miles ago I had the BRP tensioner installed. After watching the video of the aftermarket tensioner I now wonder about the BRP part’s durability. It fixed the vibration, but if it breaks, will BRP cover the repair and replacement under warranty? What if it trashes the $300 drive belt?
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    You MAY need a LASER ALIGNMENT!
    Unless they did it b4 u bought it.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Greenville Tx
    Quote Originally Posted by PaladinLV View Post
    AJ
    Vibration at highway speeds has nothing to do with the alignment. That would be a whole nuther discussion.
    I brought it up with the salesman and they still say that they already are laser aligned from the factory. I will try to at least get them to check it because they do Rolo laser alignments there. The bike handled very well on last Sundays ride in the twisties, but I could see a new sway bar would help it.
    I did order a BR sway bar today along with a ton of other stuff. It will keep me busy for awhile putting it all together.
    sway bar
    vibration damper
    bump skid
    performance muffler bypass pipe
    fog lights with rings
    front fender LEDs
    rear LED brake, turn, run,flash kit
    Garmin 590
    Greenville Tx
    Quote Originally Posted by Jambo Creek View Post
    I would also be worried about the BRP one. I have seen threads on here of failures and it aint pretty. Doc said in the video I posted that they work fine for at least a couple of years.
    Edit!! read Doc's response to this post on page 2. I would remove that tensioner ASAP!
    Greenville Tx
    Its that way with the stock hiem links that hold the sway bar. Once you change one out and see the difference, its kind of scary. The Baha Ron links are very well made solid aluminum where the BRP ones look like a very flimsy plastic piece that look kind of cracker jack. I did my ST Limited
