You can use a screwdriver. There are 4 fasteners, just pull the center out and then pull the outside part out of the hole. They may come out in one piece. You will also need to remove the black panel below the headlights to lift the frunk bucket out.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
How to get to the F3's battery:
1. pop the hood.
2. remove the bat-looking plastic cover that has a computer sign on it by pulling straight up on two lower corners
3. use flat-head screwdriver to pop the center pins of the black plastic rivets
4. pull out the base of the plastic rivets
5. lift out the tub
To replace - reverse the procedure. The only problem you'll face is that bat-looking plastic cover with the computer sign on it. Yea, you'll need to apply some rubber-safe oil or a silicone grease to the rubber grommets on each side and on the matching plastic rivets on the cover. Holding the cover in place by the center with one hand apply pressure with another hand on each side pushing down and forward.
Good luck installing that plastic cover back
Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
Speedsterjohnny,
The fasteners you are referring to are called push pins, and I got this tool from Harbor Freight (Sears sells them too), and it works great for removing them. You can use a screwdriver to if you want, but this tool makes it so much easier for me.
Push Pin Pliers
Item #67400
Only: $9.99
Compare to $19.99, Craftsman Craftsman
Is it Friday yet? ... Oh yeah, I forgot. I'm retired
Past bikes
2010 RS - Sold
2012 RT - Sold
2014 RT - Testing completed
2016 F3-T Audio package - Sold
I need to buy a set of those. The push pins are just too easy to lose using a screwdriver.
Reason: Moved Post title... ;-)
I looked at the Harbor Freight push pin pliers and they all stunk. The jaws did not meet squarely and, amongst all the pairs on the rack there was no consistency in the quality of the jaws. I paid a bit more but got a good pair from Lisle.
R.e. Harbor freight pliers: yes, I bought a pair and then true up the surfaces with a file and India Stone. You have to Be careful with any plier or you can damage the pins. Watched a tech mangle some using his Mac Tool plier.
Wayne
pauly1 - SpyderDeb's 'wrench'
IBA #48220 SS1000 BB1500
I use this tool for removing the auto push clips that are on the Spyder
Place toll under the top of the center pin don't remove the center pin completely that way you want loose it, then place tool under the main larger body piece.
I use the Harbor Freight one and I think it works great. I bought one for both my sons and a friend, they all like them.
And where did you get that tool?
Here's what they look like:
Rob
Try amazon or ebay, we can buy them from most Auto & Tool supply shops here in NZ
While looking for something not related, I came upon this, and now all I need to do is find what I was looking for.
https://www.ebay.com/itm/Heavy-Duty-...gAAOSwFb5aAizG
Past bikes
2010 RS - Sold
2012 RT - Sold
Originally Posted by Don'tPanic
1. pop the hood.
5. lift out the tub
The bat-looking plastic cover removed easily with a gentle prod using a large flat blade screwdriver.... popped right off. I sprung for a push pin pliers at NAPA which was delivered same day from their distribution center. Advance Auto, Auto Zone and Home Depot all had to order, Home Depot referring me to the online source with no offer to order for me. The push pins came out easily and out came the tub. I did use a rubber safe lubricant, but had no problem putting it back on. The push pins were a little stubborn, but I managed to get them back in too.
The reason for this procedure was the installation of a power plate from Lamonster Garage. My only question, and I raised it with their tech by phone, was why it was mounted on the left (clutch lever) side when there seemed to be so much more room on the right. Oh well, it's on, it works and I'm happy. Thanks to all of you for your suggestions.
Hoss
There comes a time in life when you really want to stay in the wind, but single-track vehicles are no longer a practical or safe solution. The Can AM Spyder is a wonderful answer to a difficult situation.
