Results 1 to 25 of 32
    Oct 2017
    Salem, OR
    Default Thumbs down on Factory Luggage Rack - Any suggestions?
    I didn't ask enough questions when I ordered a luggage rackwith my new F3-T. I am asking for suggestions as to what to do. Are there goodsized bags that would work here, or an aftermarket luggage rack that will workwith the antennae, or...?
    I have two major complaints:
    1. Very little room. Not only is it the smallest luggagerack I have ever had, the antennae reduces the effective size.
    2. It slopes down. Just seems like a bad idea.
    I have attached pictures.
    Thanks for the responses.
    Mar 2013
    Maumelle, AR
    Default Here's what I do.
    This only works if you ride solo. If you don't, put her on her own Spyder and then it'll work.
    Dowco - 50156-00 - Motorcycle Luggage System, Large Roll Bag
    2020 RT Limited , Chalk
    Oct 2017
    Salem, OR
    Default I do ride solo
    Quote Originally Posted by Copperman View Post
    I do ride solo. I was actually planning on carrying two dry bags.
    I am simply wondering if I should ask for a refund on the rack since it seems pretty. I have always had two good sized side cases, and top case, and a dry bag. The front truck F3-T is smaller than my the top cases I always purchased, and the side cases are smaller than the Givi side cases that went through three motorcycles. It looks like I will have less room, and that does not thrill me.
    Mar 2013
    Maumelle, AR
    I've always viewed luggage racks as bling. Not very functional, but looks nice. And not all look nice, but the BRP luggage rack for the F3 is one that does. If you like the way it looks, keep it. If not, return it. Just know it's only bling.
    Nov 2012
    North Las Vegas, NV
    D93230B8-AA09-4832-B8DF-9462E839E4E3.jpgHere's mine I use a top box and a dry bag on the passenger seat, no antenna problem at all.http://www.bakerbuiltairwings.com/pr...?prod=SPYF3TLR
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Harrington, Australia
    It works well for me when travelling solo. BUT...... I have a Touratech/Ortleib 75litre drybag that is around 14” wide and 25” long. I run it front to back, rack and passenger seat, rather than across, and the antennae is up against the bag but doesn’t interfere. Being a drybag it bends slightly to follow the rack angle. I can strap another dry bag on top of it if needed. But that is the only configuration I have found that works, so it is indeed limited in what you can carry.
    i can’t post picture unfortunately as I have the adjustable passenger backrest on at the moment.
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2017
    Salem, OR
    Default Can you describe it?
    Two questions:
    1. Exactly how do you prevent the second bag from rolling from one side to another when going around corners? Just cinch it down really hard?
    2. How big is the bag you put on top?
    Jul 2010
    Las Vegas, NV
    Default Straps
    That rack makes handy places to strap to.
    Joe Meyer
    Quote Originally Posted by gnorthern View Post
    Two questions:
    The Touratech has a wonderful attachment system that allows you to cinch the top bag onto the lower bag very firmly. I was thinking of my previous Ortleib when I said 70 litres. The large Touratech is 50 litres, which is around 14” wide by 25” long as per my first post. The top bag is 31 litres. I would imagine that cinching down tight would give a similar stability, depending on the bag, but I’m only guessing.....sorry.
    Looks like this -
    https://touratech.com.au/home/news/3...rcycle-luggage
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Air Wing Guy's Avatar
    Jan 2012
    Ohio
    Default Baker Built Luggage Rack
    Thanks for the post. The Luggage Rack for the Spyder F3T is simple and easy to install and holds alot! great way to mount a box to which does not effect the antenna at all. If you have any questions please feel free to call or email us. (1-800-451-9464 or info@bakerbuilt.com) These can also be found online at the above mentioned link. Thanks for your time.
    Indy
    Question Theft of Strapped down Bag
    My apologies for changing the topic, but the wife and I are planning on doing some long rides next year and the question came up do you folks UN-strap your stuff and take it with you into the restaurant to eat or just take your chances that somebody does not relieve you of the dry bags attached to your spyders.
    Nov 2012
    North Las Vegas, NV
    No unstrapping to go to eat, it does take a while to remove when going to the hotel room.439C8ACD-9671-4D75-B54D-7D78C76EA270.jpg
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    We have traveled all over the place with a dry bag strapped across my back seat. I have never had anyone try to steal it.
    Houston
    If you are going to mount a top box or large duffle behind the passenger seat on this rack, you need to move the antenna just like BRP does for the top box.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Nov 2012
    North Las Vegas, NV
    I didn’t have to, it bends.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Aug 2013
    Northern California
    vcm_s_kf_repr_882x588.jpgI strap a bag between the driver and passenger back rests. It has a large Velcro strap that wraps around passenger back rest, and straps that wrap around hand grips. This added enough space to go cross country.
    Oct 2017
    Salem, OR
    Default Happy ending
    The dealer agreed to give me store credit for my rack. I will be purchasing an aftermarket rack.
    Oct 2017
    Salem, OR
    Can you post exactly what that top box is?
    Thanks.
    Active Member noboot's Avatar
    Sydney Auustralia
    A friend of Mine makes this rack for the F3 and it's one tough strong rack
    Active Member deer30084's Avatar
    Tallahassee, FL
    There's no luggage rack that I know of that works with the Can Am adjustable passenger backrest installed.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Aug 2016
    ne Pa
    Default rear carrier
    Check out mlbinnovations@gmail.com Heavy flat carrier. I have a givi top case mounted.
    Jul 2016
    Atlanta, GA
    Default can-am spyder f3 luggage rack
    Quote Originally Posted by noboot View Post
    Does he make a rack without using the passenger seat? If so, how much are the luggage racks (over the real tire)?
    Daryl
    Quote Originally Posted by h100250 View Post
    Never done the unstrapping thing for restaurants. I do try to keep the bike parked where it is visible to me. Don't like people taking "test sits."
    Overnight stays in the hotel--don't leave anything you don't want stolen. I mistakenly left the key in the ignition overnight in Fairbanks AK. After an hour of looking for the &^%$ key in the morning, went out to the parking lot--the 's were there.
    May 2017
    Adelaide Australia
    Questio asked already, but I am also keen to know availability and price. Mine is for the F3Ltd.
    2016 F3Ltd , Red
