Results 1 to 23 of 23
    May 2016
    Cartersville, GA
    Default Looking for recommendations for a Jack
    Any recommendations for a jack for a rt limited that will lift the entire bike..... How about the harbor freight jacks....... Thanks in advance for any info
    Jan 2015
    southern WI
    Are you looking for a floor jack, or a bike lift that will pick up your whole bike?
    2016 RTS , Pearl White
    May 2017
    Mesa, Arid-Zone-A
    An inexpensive floor jack from any auto parts store is more than adequate. To lift the entire bike I use the one sold by Harbor Freight. Sears also has a good one (if you hurry before they are out of business)
    Semper Fi
    May 2016
    Cartersville, GA
    Quote Originally Posted by Mazo EMS2 View Post
    Looking for a jack tha will lift the entire bike, for oil changes an tire changes etc....
    Aug 2015
    Canton, Ohio
    I use the Harbor Freight MC/Lawnmower lift, it works fine but for whatever reason, I am the only one in the world that has to pull the front tires onto two 2x4's then lift it.
    Joe
    Aug 2013
    Colorado
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    No, you are not he only one!
    Joe
    The fit under the bike is tight but if you add air to the rear air shock to its limit, ~90 lbs, it'll lift the bike high enough to get the jack under it.
    Default Here's what I use...
    20150630_123305.jpg This one is from Sears. Harbor freight also had the same one in blue but also a similar one in black little different mechanisms.
    I've told my wife the Craftsman jack is my choice for Christmas. Stanley-Black&Decker bought Craftsman from Sears.
    Faribault, MN
    I use the Harbor Freight on my 13, no 2x4's needed, but my rear airbag is at 50lbs.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2017
    Perry Hall, Md
    As I read through the forums I compile important threads found that I keep as bookmarks by category. This is one;
    http://www.spyderlovers.com/forums/s...g-the-RT/page2
    2011 RT , Yes Blue
    Jan 2015
    southern WI
    I've had good luck with my Harbor Freight lift as well. Just look for the lowest profile one they have. I haven't had to add air or use 2x4's on our 2016RTS. It htink there are a number of threads that discuss placement and profile of the lifts. Easy Peasy, and it makes those tasks much simpler.
    Jun 2010
    Las Vegas
    We use the Craftsman Professional Motorcycle Jack https://www.ebay.com/i/263244482557?chn=ps&dispItem=1
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2015
    Tucson, AZ USA
    Default HF or Sears Aluminum Motorcycle Lift
    I suggest the HF or Sears aluminum motorcycle lift as the rolling aluminum models are much easier to position under the bike. The attached photo is of the HF model that I have. The Sears one appears to be the same other than a different set of front wheels.
    Quote Originally Posted by Ramrover View Post
    May 2014
    Benson, NY
    Let her know I just heard on the morning news that Sears is having 50% off everything Thanksgiving weekend.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Apr 2016
    Emmaus, PA
    Joe
    No you're not! I have to do the same, else the lift is about 1/2 inch too high.
    Mar 2012
    Beaverton, Oregon
    I personally like the J&S jack. It is a bit expensive but is VERY stable when the spyder is up on the lift. One up and the safety arms are in place you can spin and move the jack where ever you want it. The bike could be even stored up against the wall up on the jack as long as the jack cylinder has the pressure released. I also have the oil change pan than fits int too jack to redirect the oil into the drain pan. I used it on previous bikes and when I got my 2015 RT they built an adapter for that bike.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Feb 2013
    Northern California
    Default Another for....
    Count me in on the group using the Harbor Freight Jack. It's a bit on the bouncy side when getting all 3 wheels off the ground, but it gets 'em there! I also put jack-stands under the A-Arms and 2x4's under the rear wheel once it's up there, just in case.
    Bud~
    Dec 2015
    Oakley Utah
    Quote Originally Posted by bmwlarry View Post
    Where do those stabilizer arms go, to prevent side-to-side wobble?
    2014 RTL Platinum
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    I also use the j&s. Lifts higher very stable
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
    Active Member wd8ajj's Avatar
    Las Cruces NM
    A buddy of mine has a small Car lift from that be got on Craig's list and welded a cross plate to hold the CanAm.
    Jul 2017
    sarasota, fl
    my rear airbag is at 105 lbs. But she's not on all the time.
    Faribault, MN
    Quote Originally Posted by ofdave View Post
    And I'm guessing she doesn't read this forum, eh?
    Safe Rides,
    IBA 70020
