12v + Dual USB and RT Dash Mount
I was wondering if anyone has added the 12v Dual USB dash power to the JT's Spyder Store dash mount. I have one on order and am waiting for it to arrive. I plan on running it to the battery since it has an on/off toggle switch. I am very leery about pulling the panels off of my Spyder because I'm afraid I may break something. I have another USB port I would like to put in the blank spot where the rocker switches are but again, I am too afraid to take the Spyder apart. Any words of encouragement or how-tos would be greatly appreciated. Thanks in advance.
http://spyderstore.com/index.php?rou...&product_id=68
In the beginning, I felt the same way, but if you watch the youtube videos on removing the panels it gets easier each time. Just lay out the panels in the order you remove them and put the screws with each panel and note where the longer or shorter ones came from. I just did the same additions to mine, the dash mount, 12v & usb. Also, I added the FZ-1 fusebox, so I can add other circuits with only one set of wires running to the battery.
[QUOTE=george123;1312306]In the beginning, I felt the same way, but if you watch the youtube videos on removing the panels it gets easier each time. Just lay out the panels in the order you remove them and put the screws with each panel and note where the longer or shorter ones came from. I just did the same additions to mine, the dash mount, 12v & usb. Also, I added the FZ-1 fusebox, so I can add other circuits with only one set of wires running to the battery.
Looks exactly how I want it to. I guess I will bite the bullet and do it one day. How did you run the wire without it showing? Are they run under a panel? Thanks for the reply.
I had TricLed add the 12V. with two USB connections to my Spyder at Red Rock and they work great. Took a lot of Concern about my ability to do it right away. Thanks TricLed.
I ran the wire down the right windshield arm, zip tied, so it doesn’t interfere with any moving parts. I put the fuse box behind the panel that’s directly below the right mirror, and ran the wires from there down to the battery in the front trunk. You just have to use a stiff piece of wire or something to fish down to the battery and pull the wires through. Just takes several tries to find the right route that you can pull the wires down through. Here’s a link to the FZ 1 fuse box.
http://www.cyclenutz.com/Fuzeblock-F...FZ-1_p_92.html
You can add up to six circuits, and they can either be switched or unswitched by just moving the fuse over in the fuse box .
I installed the setup and it was easy. I pulled the wires from the dash directly to the battery. Easy peasy.
USB Power
Thank You
Mark Light
Live Long and Ride Hard
