Results 1 to 20 of 20
Thread: Hot thighs
    Jun 2017
    Arlington, Az
    Default Hot thighs
    I am new to Spyder lovers and have recently purchased a 2014 RT S. I'm really enjoying my Spyder but today I rode several hundred miles and I had a problem with my thighs getting really hot right by the glove box. What can be done? Any help is appreciated.
    Jun 2010
    Las Vegas
    What kind of pants are you wearing? A good thick pair of jeans with no nylon in them should keep you cool.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2015
    Green Bay, WI
    I love good looking hot thighs---I have a very short attention span & leave my nylons out of this conversation..
    Darrell
    Aug 2012
    CO
    Are hot thighs accompanied by exhaust popping on deceleration, or increased exhaust smell while idling? Might be a failing exhaust gasket.
    JLohPhotos
    2008 GS , Millennium Yellow
    Faribault, MN
    Though not required by '14's and later, I've heard of several who installed the '13 Heat recall vents which helped push more cool air under the side panels, making them cooler, the scoop inlet under the arrow below.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Bryant, Arkansas
    go to www.airhawk.com and buy the "R" Version Cruiser seat cushion and solve your problem, they have a 60 day full refund if it don't solve the problem
    Cruzr Joe
    Default HOT THIGHS
    Quote Originally Posted by Grumpy1129 View Post
    ..... Check your Owners Manual .... Riding - NAKED - is prohibited ...... Sorry I couldn't resist , However I have the Same year and model you do .... 35,000 mi. some in 97 * weather ... I have never felt any heat in that area ..... Mike
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    I had the heat kit installed on my 2011. Although it was designed for the 2013's I believe it fits your 2014 as well.
    it stopped a lot of the blasting hot air that was coming up between the seat and the glove box.
    The kit itself is under $70.00. I paid 1 hour labour for the install. Well worth the cost to me.
    Greg
    2015 RT Limited (White)
    .....I have the Same year and model you do .... 35,000 mi. some in 97 * weather ... I have never felt any heat in that area ..... Mike
    The same with me at 33,000+, with either Levis or mesh riding pants.
    Apr 2015
    Lodi WI
    Default Baker Air Wings
    On warm days I would open my Baker Wings and cut a breeze directly through the Hot Thigh area. Cold weather I shut them down and I picked up extra heat from the motor.
    http://www.bakerbuiltairwings.com/pr...=1SPYRTACRAWUP
    Dec 2015
    Oakley Utah
    This is the solution. Did it to both of my 2014RTLs. It comes with heat shield material for that area your thighs are closest to. Works.
    2014 RTL Platinum
    Active Member BUZZARD II's Avatar
    Dec 2016
    NoVA
    Grump, I have a 2016 RT-S and have the same problem here in Virginia, even today. That should change for the next 6 or 7 months in two more days.
    You're in Arizona, you're screwed.
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    Default Part Number for kit?
    Quote Originally Posted by Wrongway View Post
    Do you have a part number or link for 2013 Magnesium STS??
    tia,
    Dec 2015
    Oakley Utah
    Quote Originally Posted by spyderfish View Post
    Do you have a part number or link for 2013 Magnesium STS?? tia,
    I think it is only available for the RT (any color because the kit parts are black)
    2014 RTL Platinum
    Jul 2017
    tia,
    Sorry Tia but mine is an RT. Not sure what number you need for the STS
    Greg
    Sep 2009
    La Valle, WI
    I have a 15 RTS mine was warm in an around glove box. My thighs and crotch were warm. I got the scoops and now it's always cool in any temp. They look cool to.
    2018 F3 Limited , Oxford Blue
    Jul 2017
    Quote Originally Posted by JP58 View Post
    You're right about the scoops looking cool. A guy with a 2014 RT came up to me at a coffee shop the other day. He wondered what year my Spyder was because of the scoops.
    I explained it to him and he said that he doesn't care about the acoustic panel modifications but he's going to order the kit so he can have scoops.
    His spyder is white so it should look pretty cool.
    Greg
    Vermont
    I have a 2014 RTS-SE6 and I haven't had that problem.
    I wear jeans when riding.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jun 2017
    Arlington, Az
    Quote Originally Posted by asp125 View Post
    No, I was riding across the desert and it was 105deg.
    Jun 2015
    Hampton Roads, VA
    Default Try the scoops!
    I installed the scoops (pics in another thread) on my 2016 RTS. Big difference in heat near the glove box. The kit is only $50 (which is amazing). However you gotta drill holes in your tupperware. You'll probably miss one or two spots, but they get covered up. Also the plastic is cheap looking, I used black plasti-dip to paint them before installing. You can see the shiny plastic above - was already scratched up with tiny scratches out of the box. Kit comes with stick on insulation for the tupperware also, that helps keep your legs cool. Works great so far, glove box stays same temp as outside now instead of baking my phone!!
    Details in this thread: http://www.spyderlovers.com/forums/s...ghlight=scoops
    Steve
