Results 1 to 22 of 22
    Ashburn, VA
    Default Filling gas to the rim or?
    Hi folks!
    When filling up your gas, do you stop at the pump shut-off or do you fill it to the rim? (Well, not quite the rim because closing the gas cap will cause overfill, but you know what I mean).
    When filling up the gas comes up to the rim and then bubbles/settles down into the tank. It does this several times before I can't fit anymore into it. Is this a bad idea? Should I just stop when it clicks off the first time?
    Thanks!
    SS
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by SpyderSkeets View Post
    Hi folks!
    Thanks!
    SS
    That's exactly what I do most times. Haven't had any troubles. 2600 miles.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Default Here's what I do.....
    Wise member here (Nancys Toy) figured this to be just the right point for filling your tank. When the cut off kicks in move the nozzel up just inside the rim of the filling tube and continue slowly till it bubbles around the breather slots..Then your as full as you should be. More and you will fill the canister etc...
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    x2 for me. what he said.
    [joyce & irvin toms]
    Hi folks!
    Thanks!
    SS
    I do what you do and have not experienced any known problems doing so.
    Sep 2016
    LI NY
    Same here
    2010 RTSM5 , stock Stock Silver
    A slight variation, but similar. I do not use automatic shut off. Fill to ring, stop, let the gas settle and fill up to ring second time. Done. Requires a steady hand and good control on the dispensing handle.
    Active Member El Dorado's Avatar
    Jun 2017
    NorCal
    F
    For those of us that live in a nanny state that use the elephant vapor collection nozzle, this easily defeats that feature and allow a real top off to fill. It came with my bike but would not be hard to make
    2015 RTS
    Replaced Catalytic Converter with Lamonster Pipe
    Rivco Flag Holders
    Tricled wideview mirrors
    Garage door opener
    Zumo GPS
    Ultimate seat
    F4 windshield with vent
    Doc's belt damper
    Value Accessories RAM mount
    Baja Ron sway bar and Links
    Jan 2015
    southern WI
    Hi folks!
    Thanks!
    SS
    Why not just do what you do with your car or truck?
    2016 RTS , Pearl White
    Nov 2015
    Just looking at the service manual for the Critter & it looks like the EVAP canister is located above the tank. And the vent valve in the tank is also at the highest point so there is a very small chance of flooding the EVAP canister. I'm not saying that it can't happen thou.
    Wasn't this a problem with the pre-2014 models?? Just asking, not sure. Thanks.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2016
    Bloomington, Minnesota
    If I am going a distance after fillup, I go to the brim, you never know where the next stop will be. If I am headed to the barn, I never go to the brim. When the bike is stored, temps vary, especially when brought in hot. you should always leave room for temperature expansion.
    Nov 2015
    Quote Originally Posted by PapaHotel View Post
    I always fill up several miles from home to insure the trike isn't full when parked. Thanks.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Ashburn, VA
    Quote Originally Posted by Mazo EMS2 View Post
    On my truck, I almost always fill it to the rim, and when I do, its filled and there isn't much "settling" of the gas. When I do it with the Spyder, there seems to be an usual amount of "settling" and it seems that it might not be the right thing to do. I know you're usually not supposed to top off and I just want to be sure it's not causing any kind of issue with any of the sensors
    Apr 2017
    North Central Florida
    Yes and yes......IF the nozzle lever feels really stiff, like many of them do.
    I've found that many times it makes a nasty mess by going past the first shutoff.
    AND.... I have found that the additional you can get in by pulling the nozzle out a bit and going for the second click really isn't much.
    But I still do 2 clicks. Maybe someday I'll convince myself to stop doing that.
    Apr 2017
    While I agree that could be really good advice............most of the gas pumps that I have used don't have a "slowly" setting.
    The flow is either OFF or ON FULL BLAST.
    That makes it impossible to finesse the level.
    Default WELLLLLLL NOW THAT YOU MENTION IT
    You can't do it this way because The Spyder has no NECK ....you can see the top of the tank ...... on your car / trk there is generally more than 8 inches of pipe before it gets to the Tank .... on the Spyder you can actually see the gas tank ..... Mike
    Vermont
    Hi folks!
    Thanks!
    SS
    I also do the same thing, I fill up gas tank, until I can't fit any more gas in. I have a 2014 RTS-SE6 with 21,800 miles. No problems.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Apr 2017
    No problems.
    Yet.
    Doesn't it concern you at all that:
    BRP says not to do that.
    Other owners have reported that they DO have problems caused by over-filling ??
    I guess not. I hope your luck holds up.
    Yet.
    You are partly correct , some owners - the ones that have / had the V-twin engine and the way BRP routed the gas overflow and the position / location of the EVAP / Charcoal canister .... This ALL changed with the 1330 engine & frame .... Now only fumes can reach the canister ....not gas ...... Mike
    May 2009
    Connecticut
    I have Never filled it till it clicks off? I don't take long trips . Its Not worth replacing a canister or gas fumes? Do whats best for you!!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Right! I keep thinking I need to watch the pump to see just how much more I actually squeeze in by finessing the nozzle handle for an additional minute. What, maybe 2 quarts! Actually I push to get to an even 25 cents. The last dollar's worth is slow getting in!
    Active Member wd8ajj's Avatar
    Las Cruces NM
    Quote Originally Posted by El Dorado View Post
    F
    Are those available through a non BRP? Traveling into Calif later and that would be a massive help on the trip. Or take measurements of all and post so one can be made. Wonder if Lamonster is interested in selling them. You might send him an email and see.
