Page 5 of 5 FirstFirst 12345
Results 101 to 115 of 115
  1. #101
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Machinegunner View Post
    In Wisconsin, I go to Schierl Tire to get my General Alitimax, no questios asked. I take it to my Spyder dealer to have it installed and balanced, no questions asked, either.
    Which General Altimax size is recommended for the 2013+ RT?
    General AltiMAX RT43 Radial Tire - 195/65R15 91T $64 on Amazon https://www.amazon.com/General-AltiM...3+%5BT%5D+Tire
    General AltiMAX RT43 Radial Tire - 215/60R15 94T $83 on Amazon https://www.amazon.com/General-AltiM...3+%5BT%5D+Tire
    I know there has been some discussion about the preferred profile but it's kind of hard to follow through the various threads. Thanks.
    2014 RTL Platinum
  2. #102
    Default THE ALTIMAX
    .. Pete it's the 215 ..... and see if it's the " T " speed rated one , because it's better than the H or V rated ones .... I know this may be contrary to normal thinking but it is ..... Mike
  3. #103
    Dec 2015
    Oakley Utah
    Mike, I'm assuming the 94T means T-rated ...?
    2014 RTL Platinum
  4. #104
    Dec 2015
    Oakley Utah
    Walmart has a pretty good price on this $71 + tax and free shipping...
    2014 RTL Platinum
  5. #105
    Correct. The '94' is the load rating; the 'T' is the speed rating.
  6. #106
    Dec 2015
    Oakley Utah
    I figured I could count on you, Pete.
    Just ordered it from Wal-Mart. We'll see how that goes finding a shop to mount it!
    2014 RTL Platinum
  7. #107
    Local tire shop mounted my General on my rear wheel, and my Continentals on the front wheels. I took the wheels off the Spyder and took them and the tires to the shop. Charged me $10 mounting and $10 balancing for each tire. The rear was balanced with "Liquid Balance", which is a brand tire shops use. No questions asked!
  8. #108
    Default T-RATED
    .... Yep, someone posted that the other day ..... Those ratings are arrived at by testing the tire at those speeds constantly for " X " amount of time....." T" rating is 118 mph ( sustained speed ) ...this is almost DOUBLE the normal constant speed anyone drives their Spyder at ...... and this based on a vehicle in the 4000 lb range ....not an 1150 lb Spyder ...... the weight make a HUGH difference ....lighter is better ..........Mike
  9. #109
    Mar 2018
    Danville Ky.
    yes a lot of wing riders use car tires.. call it the dark side. Really good on a goldwing when you pulling a trailer. On grass as well a car tire on wing will just walk out where a car tire leaves a wing spinning..
    look up dark side
    Harley riders have been using car tires - probably from day one.
    2014 RT Limited , stock lamonster flat silver
  10. #110
    Mar 2018
    Danville Ky.
    comment
    i rode a goldwing for years and gee way over 100,000 miles without one issue. a car tire - for me- had better traction in all conditions. PLus pop the clutch at 3500 rpms and the wing would drag the pipes .. was fun and easy to pop a willy with car tires.
    jim
  11. #111
    Mar 2016
    Payson, Arizona
    Although there are lots of answers, just say Fiat Spider. I call that a white lie.
    I go to a motorsport dealer who sell ATVs, Quads and the like. I have the tire delivered, drive in, and in about 30 minutes and $80, they remove, mount and balance and reinstall the rear wheel. They are a CanAm dealer, and also work on HDs. I gave the service manager a maintenance CD for my model.
    I believe they told me they would service my Spyder.
  12. #112
    Aug 2010
    Cloquet Mn
    Quote Originally Posted by asp125 View Post
    Here is a partial list of cars that use 15" tires. https://www.wheel-size.com/tire/205/65R15/
    The 205/65R15 should not be used too tall. The 205/55R15 is a good replacement for the 225/50R15 OEM tire and a lot more choices.
  13. #113
    Quote Originally Posted by bobbobtar View Post
    The 205/65R15 should not be used too tall. The 205/55R15 is a good replacement for the 225/50R15 OEM tire a lot more choices.
    I think most of us here who are using CT on the rear went with 215/60R15. Fits nicely and brings the speedo pretty much dead on for speed.
  14. #114
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by jaherbst View Post
    You ran car tires on your Goldwing? Tell us about it. I think this is a first!
    Jack
    Going to " the darkside" on a GW or a Valkyrie has been around for a long ,long time. I had a 98 Valk ( a wonderful bike BTW) but NEVER thought of putting a car tire on the big girl.
    Lew L
    2014 RTS , Circuit Yellow
  15. #115
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by azprince View Post
    Just curious..... Was the dealer Four Seasons Motorsports? I think they are a pretty good dealership and used them when I had a CanAm Commander. I stopped there a couple of years ago to see if they would work on a Spyder. (Even though they did not sell Spyders). The Service Manager told me that "This is the first time I have seen one in person". Hoping they have jumped into servicing Spyders..... We need more competition for service in our area..... Jim
    Semper Fi
