Results 1 to 11 of 11
Thread: F3 2-UP SHOCK
    Apr 2011
    GREENVILLE, SC
    Default F3 2-UP SHOCK
    Just installed my F3 2-UP Shock Absorber...
    I bought it from my very new best friend Jim from LA... he advertised it here on SL, and I grabbed it...
    From start to finish, it took exactly 1 hr...
    i looked at the clock, and waited until exactly 11:00 AM....
    all you need is to get the read tire off the floor, a 15mm deep socket, and a 15mm wrench, a torque wrench and a small scissor jack...
    remove the nuts top n bottom, and pull out the bolts... here's where you may need the scissor jack; to align the bolts and bolt holes, you'll need to place the scissor jack under the read tire, and finagle it until the bolts can be removed by hand... put the OEM stuff aside...
    install is just the reverse... i did bottom bolt first, then top... torqued to 36 ft lbs... lowered SPYD3R, cleaned up my tools, put everything away, looked at the clock, and it was exactly high-noon, 12 o'clock....
    now i'm upset because it's raining, and will be for the next few days.... boo hoo hoo.....
    if anyone has any questions about this process, i'd be happy to answer (if i can)...
    Dan P
    SPYD3R
    20170830_110440.jpg 20170830_113519.jpg 20170830_113900.jpg 20170830_190050.jpg 20170831_113737.jpg
    thx Jim....
    Jun 2017
    Wi
    I put one on a few weeks ago. A bit stiff at first, then breaks in nicely.
    Default Nicely done...
    for the visuals and nice touch painting the sping to match...did you consider the time to tape up the shock for paint....
    Apr 2011
    GREENVILLE, SC
    Default paint
    NO, the masking and painting were not included in that one hour... one hour was for installation only... lots of fun however...
    Dan P
    SPYD3R
    May 2009
    Connecticut
    I Put it on my 2015 F3 and Its Much Stiffer Than stock BUT I'm only 210 so it would be? Actually if you are under 200 Pounds and Don't ride with a Passenger EVER I would leave the stock one on? I Does Handle corners Better!
    Sea Doo GTI-SE 90 Jet Ski!!
    May 2016
    Central Florida
    I hope that paint and/or the non detectable tape residue doesn't interfere with the shock compressing correctly.
    Apr 2011
    GREENVILLE, SC
    Default wow
    WOW..... ! ! !
    just got back from my 1st ride with the new 2-UP Shock.... WOW...! ! ! big difference, and a good 1 @ that.... this is gona be fun...
    I highly recommend this upgrade if you ride 2-up, or are over 250 lbs... i'm 265#, and this works gr8 for me.... SPYD3R feels way more stable in turns, and bumps are handled better as well...
    Dan P
    SPYD3R
    Feb 2015
    New Orleans Westbank - Belle Chasse, La 70037
    Default Great Thread, Dan
    Your a show-off at heart, Dan. but then that's the nice thing about these bikes; you can't go anywhere that people won't gawk at and ask questions about these bikes of the future. I predict, if the Lord terries, that these three wheeled wonders will not only be electric driven but come with side cars, one on each side of the rear wheel for two more riders plus a trailer hitch that comes standard to pull the camper because this thing is really fun for the whole family.
    Apr 2011
    GREENVILLE, SC
    Default thx
    Quote Originally Posted by jimmybarton View Post
    All thanks to you Jim....
    dp
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default uncertain
    Quote Originally Posted by SPYD3R View Post
    WOW..... ! ! !
    Dan P
    SPYD3R
    I also just installed a two-up shock. I doubted that it would make much difference, but it was a compromise with my wife rather than jumping in and buying the six hundred buck Elca. I was wrong, it's made a huge improvement in the ride and has pretty much stopped the bottoming out we felt with the standard shock. This should be the factory standard shock.
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Anyone know what the Two-Up shock is rated at weight wise ? 2-3-400 lbs .
    Happy Owner
