Removing Pine Tree Sap
Anyone know what may be safe to use on a BRP bike cover, to remove pine tree sap?
2014 Can Am Spyder RT Limited - Pearl White
2010 Can Am Spyder RT - Full Moon ![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.WY.ND.SD.KS.OK.TX.MN.MO.AR.LA.WI.IL.MI.IN.KY.TN.OH.WV.NH.VT.MA.RI.CT.NY.PA.DE.VA.IA.NC)
Hi SteveandBelinda,
Re: remove pine tree sap?
I had a pine tree next to my driveway when I bought my current house. I had the tree removed after dealing with this for too many years.
I do not have a better answer,
Jerry Baumchen
![Quote](images/misc/quote_icon.png) Originally Posted by SteveandBelinda
Try a product called "Goo Gone". It works on a heck of a lot of sticky residues, but I don't know if it is compatible with your cover, it could damage or remove color from it. It's available at a lot of places, Walmart, etc.
Just Google Goo Gone...
There are laundromats that have machines that will take a sleeping bag. They will be big enough for your cover and a mild laundry soap will take out the tree sap. Woolite, Arm and Hammer, something like that. If you have the time and the energy you can hand scrub it with those same soaps.
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
Dab the alcohol over the sap until the sapcomes off. Add a little mild dish soap to another corner of the cloth dampened with water. Wipe the fabric to wash away any remaining residue. Rinse the white cloth, then wipe the previously sappy area once again.
How to Get Pine Tree Sap Out of Fabric | Home Guides | SF Gate
I've heard it said, that WD-40 will take it off of a bike.
But I'm not sure what it would do with a cover... ![don't know](images/smilies/shrug.gif)
Put some of it on a rag, and perhaps try holding it against the sap (to soften it up...)
Pine tree sap is petroleum soluble and cedar sap is water soluble. Hope that helps.
Not from home. Got this a couple weeks ago when parked at hotel.
![Quote](images/misc/quote_icon.png) Originally Posted by JerryB
Hi SteveandBelinda,
Jerry Baumchen
Be careful
Petroleum based solvents might remove the sap, but also some waterproofing coatings and fabric protectants. Be sure to test on an inconspicuous section first and re-apply fabric protectant afterwards.
JLohPhotos
![](signaturepics/sigpic10708_2.gif)
I sat in sap with my Gortex riding pants and didn't have any luck with goo gone. Eventually the sticky came off but I was left with a white spot on my black pants. I may try the alcohol remedy listed above.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Yes, if it's pine sap by all means start with the least powerful petroleum product first. Try it on something other than the lid of your fronk. If you're like most of us that live in the pines there well be many samples of pine pitch everywhere. Experiment on something else first. I use regular gas and it works well for me. Example, if I dribble gas on the side of my spyder while fueling up, I just wipe it off. No harm done. Good luck.
Solvents are dicey
Steve and Belinda,
I do believe there is any solvent thatwill dissolve the sap without harming or at least marking the cover.
I have had some luck over the years with sticky stuff using a powder approach. Perhaps dry baking soda rubbed onto the sap spots, maybe it will attach to the sap and release it from the cover. Other possibilities could be talcum/baby powder, flour, confectioners sugar; any really fine, inert powder is worth trying, I do not think it will hurt the cover.
Just an idea, not proven.
Gerry
maybe this
Try putting an Ice Cube on it and scraping it with something not too sharp .... this has worked on a few other things like Gum ..... PS this won't stain ..... Mike
Removing Sap
First read this on a hot tub cover manufacturer's website. Use olive oil. I have tried it and it works almost instantly, at least on sap from Douglas Fir and Western Red Cedar.
2014 RTL SE6 Pearl White, Mfg. date 1/28/2014
BRP heated seat, BRP backrest, SpyderFlap, Tricled mirror turn signals, KOTT Grills, BRP adjustable side air vent, Bumpskid, Bajaron sway bar and heim links, Spyderpops belt guard, Tricled day lighters, Tricled fender LEDs, CD HMT running/brake LEDs
Sap removal
Use hand sanitizer. It is alchohol but will sit on the sap longer than liquid alchohol. I keep a giant bottle in my shop to safely remove sap from the toys. Let it soak on the sap for a long time.
Lucky
2015 RTS SE6
2008 Harley Ultra
1999 BMW R1200C
1986 Harley Electraglide
I second this...
It works..
![Quote](images/misc/quote_icon.png) Originally Posted by Lucky
IT IS, WHAT IT IS...
![](http://www.visitedstatesmap.com/image/CTNJNYPAmed.jpg)
Good old WD-40 works great for me. Then a mild detergent to take out the residue.
Back in the day....
My grandmother used Crisco to remove just about anything off of just about anything.
