Results 1 to 9 of 9
Thread: Clutch
    Jun 2008
    BUTLER,PA
    Default Clutch
    Anyone have any clutch issues? Clutch went out on my 2012 and had it replaced 2 years ago. i have less than a thousand miles on the thing and while going up hill rolled on the gas and its slipping. It goes back in for a check. No I'm not slipping the clutch.
    Default Well....
    Are we talking about an Se or Sm..? Depending on the first change, if automatic, did they replace the springs and or use the right ones..? Did they replace both metal and fiber plates..? Are you keeping the rpm's up high so as not to slip the clutch..? If manual it is curious if it failed already. Maybe go to a Barnett clutch kit...
    Nov 2012
    North Las Vegas, NV
    Another question is what oil are you using? The SE for sure is picky on what oil is used.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2008
    BUTLER,PA
    Thanks guys. It's am SM. If its going again I will opt for the Barnett clutch. I wasn't aware that they made one for CAN Am but I went and checked and they do. Again thanks . If it needs a new clutch I think I'll look for a different shop to install.
    Oct 2015
    Lynden, WA
    Default Clutch Issue
    Just curious as I live in PA.
    What shop did you use for the first repair/installation?
    Which shop will you go to next?
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Sep 2016
    LI NY
    Quote Originally Posted by MSGTDOC View Post
    It's a pretty easy install
    2010 RTSM5 , stock Stock Silver
    Jun 2008
    BUTLER,PA
    Quote Originally Posted by Haze View Post
    Stiller Motor Sports
    Jun 2008
    BUTLER,PA
    Quote Originally Posted by Zip View Post
    I guess if you know what you are doing. I don't
    Jun 2008
    BUTLER,PA
    Had the Barnett clutch installed and it's harder to pull the clutch lever back but engages better than stock. The service manager said it's a lot more beefier than stock. So we will see.
