DATE WHEN TIRE WAS MADE
I have looked for this info because it's been posted but can't find it ..... somewhere on all tires is a code that enables you to figure out when a tire was made ( approximately ) ....... Thanks .... Mike
On the sidewall of the tire at the end of the DOT information there is an oval with a four digit number in it.The first two digits identiify the week and the second two digits identify the year.
It is prefaced by DOT
This URL may help you in your quest
https://www.tirerack.com/tires/tiret...170817004507:s
Looks like we all went to the same place at about the same time.![Roflblack](images/smilies/roflblack.gif)
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
I owe the information to SpyderAnn who explained it to me specifically concerning the last date for the soft rear tire compound on the 2014 RTs. Any tire with a date later than 2814 was one that had the old, harder compound that was brought back when so many owners complained about very short rear tire life in the new tire compound.
Ozzie Ozzie Ozzie
There will be dot on both sides, one side of the tire has 12 digits, the last 4 are the week & year of production
DATE OF TIRE
