Spare key
When out touring do you carry your spare key with you, if so, where do you carry it?
Hi Tyris,
Re: do you carry your spare key - - where do you carry it?
Yes, I do carry one on my Spyder. No, I am not going to tell anyone where it is.
Jerry Baumchen
Spare key
Yes I carry one. If you can find an Ilco 270X blank and have it cut to your Spyder key it will work to open any of of the locked compartments that you have.
However, a little file work is necessary. For my F3 the notches on the edges of the key were too low I filed new ones to match up with those on the original key. A lil fine tuning and it works like a charm. Slip in to your wallet and you are good to go.
I'm in Jerry B's camp. I also carry an Ilco X270 in my wallet just in case.
Spare key
I have the spare key under the seat with Velcro. I have a spare key from a blank that only unlocks but won't start in my wallet to unlock the seat.
I carry my spare key in a empty jeans pocket.
Yellow 2013RT SE5(Previous)
Champagne Metallic 2017RT LTD SE6
I never leave the house without a spare key. I keep it locked in the rear trunk, and have an unchipped key hidden on the bike that I can get to without tools in case I lose the ignition key, some disassembly required . When off the bike the ignition key is on a carabiner on a belt loop rather than a pocket. (Learned that the hard way). I also have a BRP programmed key (not a clone) that never leaves the house.
Bob
I do...😆
Carry a spare...in my pocket and the one in use on a lanyard around my neck with oem sheath...and one more at home if all else fails...
my spare is on my wife's ,and hers is on mine. simple as we are ether together or close.
Louise and I each carry a spare key in our wallet. A flat Ilco X270 cut to fit.
We carried spare keys with us on our RV trip, one for each bike and carried them on our persons when riding.
JLohPhotos
