Results 1 to 8 of 8
    Active Member gman214's Avatar
    Mar 2015
    Tennessee
    Default Frunk won't open...SUGGESTIONS??
    Went to open frunk and turned key with no click sound from frunk! Pushed down a little as I turned the key and NOTHING! Any suggestions how to get the frunk open?
    Currently Own: 2011 RS-S SM5 - BRP Comfort Seat, Juice Box Pro, Two Brothers Exhaust
    Previously Owned: 1991 GS500E
    May 2017
    Perry Hall, Md
    I think there's a thread with some good tips already started.
    2011 RT , Yes Blue
    Dec 2015
    NE Ohio
    I have an RT but it might work on the other models. It's possible that the rubber seal slipped. Have someone push down on the frunk lip gently while you turn the key.
    Default HOW TO OPEN FRUNK
    Quote Originally Posted by gman214 View Post
    I posted to a member awhile back ....exactly How To open any GS - RS frunk .... I'll see if I can find it ....... Mike
    Default HOW TO OPEN FRUNK - con'td
    Sorry but among my other shortcomings I can't do LINKS ....... But good news I found my written instructions which another member used and it worked great ..... In the search box above type ( in capitals ) STUCK FRUNK .... when the answers pop up ... the fourth one down from spyd-man (?) is the Thread .... go to that and my post is # 15 ... it worked for Him ...... good luck ..... Mike ........ PS the plastic hood is a lot stronger than you think, so you don't need to worry it will break ..... unless you try to go 6 inches plus ......
    Jul 2017
    Ramona, CA
    Active Member Bandera's Avatar
    Bandera, Tx
    Default same thing happened to me.
    I bought a cheap set of mixing spoons with the long round handle. If you slide the handle between the lip of the frunk toward the latch, you can catch the release. This happened to me a couple times, so I always travel with a mixing spoon with a long round handle.
    Michael
    W5MWI
    USN Vet - RM1
    Member: VFW & American Legion
    2020 Spyder RT-L - Jupiter Metallic Blue Chrome
    Normal, Illinois
    Default could be a bad ignition switch
    I had sporadic problem getting frunk to release and to relatch on my 2014 RT-S recently. The ignition switch was eventually replaced under warranty. In the mean time, the tech instructed me to put the key in the ignition and give it a quick, sharp rap to activate the frunk mechanism. It worked well until I could get the switch replaced.
