Results 1 to 25 of 35
    Jun 2015
    Midland, TX
    Default 2nd Smartphone Lost off mount and destroyed
    My luck with cell phones is.....well no luck at all. I have now destroyed two Galaxy 7s that have bounced out of my RAM X Grip and destroyed in 4 months time.
    What mounts are available and reliable that you are using. Oh by the way, I can no longer get insurance on my phones. I've lost or it's been destroyed 3 phones in the last year and the company canceled my phone insurance.
    My wife won't let me buy anymore phones!
    Well that sure sux...
    Why do you have the phone in a mount?
    Are you using it as a GPS? You might consider just buying one of them.
    With your luck: it might be safer to just keep them in your pocket.
    Sep 2014
    USA
    I had a tablet on mine and never fell out..
    HAve you called ram about there grip x mount?
    Jun 2015
    Midland, TX
    I run the FOBO app for Spyder and Freedom trailer and use it as a secondary GPS as well. I have the Zumo Garmin 660LM. My backup phone and last phone I have will stay in the top case until I can find a secure mount.
    Jun 2013
    queens ny
    you can look for something like this to tie around the phone and mount to hold the phone in place. check staples also
    https://www.amazon.com/Cable-Ties-St...ll+velcro+ties
    Sep 2014
    USA
    Mar 2017
    Salisbury,NC
    I just bought a X grip. It has a rubber flex that goes around each corner. Did you use that? Or did it come with that? My Galaxy S5 with a cover around it fits well and I don't need flex rubber
    Jun 2015
    Midland, TX
    Quote Originally Posted by Woodaddict View Post
    The 7s Active and Edge, the rubber tether isn't big enough for the phone and case.
    Jul 2015
    Indianapolis
    Default Bummer...
    I would suspect there is something wrong with your mount. After the first one I would have tethered the next...maybe you are just not meant to have a cell phone .. could be a good thing... mine is blue toothed to my comm system and goes in the frunk....
    Apr 2012
    Northglenn Colorado
    I always use a little bit of Velcro on the back of my phone case and the center of the Phone mount just for extra hold. Works like a charm.
    Jul 2013
    Vestaburg Michigan
    Go to pro grip web site , the have holders for specific phone. I haven't lost mine in three years!
    Nowhere
    SlipGrip car mounts has kydex mounts for your phone and case. Here's a link for my Apple 6s with Lifeproif case
    http://www.slipgripcarmounts.com/Sli..._p_157515.html
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Sep 2014
    USA
    Not sure why you would leave the phone in the case and expect the holder to keep it secured properly.
    Faribault, MN
    I have a Samsung Galaxy S7 and got tired of the X-Grip hitting my volume buttons when I use it in landscape mode, mine is mounted over my dash on my RT. I switched to using an IPOW universal cell phone mount, that also works as a tripod mount, selfie stick mount, etc. I like it because it has the one thumbscrew to tighten and firmly grip the phone WITH Impact Gel case. I rode 1700 miles with my phone over oft time bumpy roads in MN, IA, KS, NE, SD, and ND, then last week did a IBA SS1K through MN and IA, and my phone never was an issue.
    Using the TricLED Spyder Dash bar, some RAM mount components, and the IPOW cell phone mount I got this over my dash.
    Here it is with my phones case mounted just to show how the phone might look in the mount.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Apr 2012
    Northglenn Colorado
    I thought that was the point of X-grips, they grip around the object they are gripping. Anyway the same applies, you can put a little Velcro on the back of your "phone" and a little in the center of your grip for extra hold.
    Sep 2014
    USA
    Quote Originally Posted by Tazzel View Post
    Let me know if you put yours in the X Grip with the holder and if its stays in place
    Jun 2015
    Midland, TX
    Because the case keeps from breaking when I drop it. It's a slim line case. My phone and case sits firmly into the X grip. Both occasions I hit a bump in the road the x grip flexed and the phone came out.
    Apr 2012
    Northglenn Colorado
    actually it does
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Quote Originally Posted by KJWEB View Post
    I have 2 ram mount x-grips with the tether and if it is on there properly, it will not jar out. When i first got it, I thought there was no way for the tether to fit, but it does. I have iphone 7. I can send you a pic of it after I get home from work.
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Jun 2015
    Midland, TX
    Quote Originally Posted by Kredab View Post
    Thanks. I think my x grip has a problem. It's flexing on hard bumps. That is what happen to both phones right after I hit the bumps.
    Oct 2015
    Iowa
    I'll send you a pic tonight, hmmm, sounds interesting, I don't think a phone could fall out with a tether attached. You could also send me a picture of your set up......
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Jun 2015
    Midland, TX
    Uh.....I threw the X grip in the trash since it has cost me two phones.
    Apr 2017
    Enfield, CT
    Are you sure you had the correct size tether? There are different sizes. I have an iPhone 6plus with an Otter case and it works. Is your phone bigger than that? I get ribbed a lot for having such a big phone lol. Cant see many phones being larger.
    Feb 2009
    Ceresco, Michigan
    The Tech Mount works GREAT and you will not have your phone come off of it....
    http://spyderpops.com/f3-roadster-te...the-smart-way/
