Results 1 to 21 of 21
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default How do I clean INSIDE my window?
    There are some spots and junk inside my window. I can't reach it to clean it. What does a person (like me) do to clean that area?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Quote Originally Posted by BigGuy66 View Post
    Its a giant pain but to get those spots off you will have to remove windshield. A lot of people just live with spots or go to wrapmyspyder.com and get a piece of vinyl film to cover that area
    Aug 2013
    Northern California
    Default Easy
    Just feed a rag or towel in between the Windshield and the bracket and pull it through and rub I think back and forth until you losen up the dirt.
    Don't sweat the small stuff. A dirty bike is a sign of a ridden bike: that is a sign of a happy rider!
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Quote Originally Posted by Pirate looks at -- View Post
    +1 Easy to do, use a cleaner on the towel (use a thin towel as it will go through easier. I don't clean that area every time, but I do get to it a few times a season!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Maybe the "Alaska Grunge" look will be adopted by others. One washing of the "nanner" so far this year. The "baby" has yet to be washed. So many hours, so little time to ride.
    Mar 2016
    Willis, Michigan
    I pretend the spots don't exist. There are times when you just have to appease the Dirt Gods and let them have a few nooks and crannies.
    Jul 2010
    Las Vegas, NV
    Default Remove windshield
    Takes 5 minutes. Then,treat the area with rain x for plastic. Keeps it nice longer.
    Joe Meyer
    Default CLEANING THIS AREA
    ........An old cotton " T" shirt works very well .....it's very thin ..... the trick is getting some in to start the process ... a piece of wire with a hook works ........... Mike
    Aug 2015
    Canton, Ohio
    Though I would preface that with dampening the rag with cleaner that you use on the windscreen. It is really easy.
    Joe
    Aug 2016
    Ok then - will get a thin towel, dampen it, a little Rain X, slip it in there and clean the windshield. IF i wanted to remove the windshield, is there a video for that? I like to see it done before I start and then have to come back on this forum and ask all of you "How do I fix this XXXX I just broke?"
    Jim
    Feb 2013
    Edinburg, TX
    I just blast water through there with my pistol-grip nozzle on the garden hose... it gets most of it out OK, if not quite all. Good enough!
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Removing the windshield...
    1.Remove the two screws that you see on the back of the windshield (one on each side...), that hold the trim-piece in place
    2.that trim-piece needs to be slid downward, and it will then pop loose from the windshield.
    (HINT: slip a playing card under the bottom edge of it, and use that to keep it from scratching the windshield...)
    3.Now you can see the four screws that hold the windshield in place (two on each side...) Have someone support it, while you unscrew them!
    Easy-Peasey!
    May 2013
    Stanton, ca
    Bob
    Jun 2013
    queens ny
    a piece of paper towel or something, and a paint stirrer or something thin, and go in from the bottom
    After I've washed and rinsed the upper and under sides of my windshield I use a microfiber cloth folded over an old plastic insurance identification card (a hotel room key card you forgot to turn in works well) and slide it between the windshield and and frame. It's been doing the job just fine for 2 1/2 years and 25K+ miles.
    Invalid Emails
    May 2016
    Columbia,tn
    I agree with cuznjohn. Use a soft cloth and a paint stirring stick. Use a wet one first then a dry one to finish it off.
    Default PAPER TOWELS -- NEVER
    Quote Originally Posted by cuznjohn View Post
    NEVER NEVER USE - PAPER ANYTHING on Plastic ..... Paper is made from WOOD and will Scratch the Plastic ..... maybe not an F-4 ..... but that is the exception ........ Mike
    May 2016
    Valley Center, CA
    I once knew a German moldmaker who specialized in polishing cores and cavities of very expensive medical device molds. He had 3 or 4 brands of tissue lined up on his bench, and he had graded them according to the abrasive qualities of the tissue. I forget which brands he used, but he had specific uses for each one.
    Default PAPER = SCRATCHES
    Quote Originally Posted by Stumpy6Guns View Post
    Exactly...... paper is an ABRASIVE ....... and ABRASIVES = SCRATCHES ...... Mike
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Thumbs up
    Totally agree with this, nothing touches my windshield but clean microfiber cloth. Even though I have an F4 windshield now, still use microfiber, it just cleans better. The Spyders body gets the same treatment, microfiber only. And separate cloths for the body and windshield.
    2015 RTL , Red
