Results 1 to 17 of 17
    May 2017
    madison heights va
    Default brand new to site
    just purchased a 2014 rts and had it wrapped. wanting to know if anybody will be at myrtle beach bike wk on on your spyders. i live in madison heights / lynchburg area in va. hoping to get a lot of info from this site.
    May 2017
    madison heights va
    what tire pressure for 2014 rts stock tires? new to site. thanks
    Harrington, Australia
    Quote Originally Posted by steelerman View Post
    Welcome Steelerman.....
    Quick searches will usually give you this type of general info. I am not saying this to be a smartarse, but just that you can usually get an answer (and varying opinions) very quickly.....here's one to start with the info you need in it.
    http://www.spyderlovers.com/forums/s...+pressure+2014
    HeliBars Handlebars
    Kenda Kanine rear.
    and RE: Tire pressure: start with 18 # in the fronts and 28# in the rear.
    Default Welcome. ..
    Congratulations on the new ryde...do need a picture for proof positive..... You did come to the right place for anything spyder. Tire pressure is a trial by error thing depending on the tire terrain and style of ryding. Factory recommended pressure are on a sticker on the swing arm on most models...
    Aug 2015
    Canton, Ohio
    100% but opinions vary, I hav e been running those for. About 2 years now, well almost.
    welcome aboard!
    Joe
    Welcome! You've latched onto a great vehicle. Since you say you're brand new to the site I assume you have not prowled around it much yet. I suggest you go to the Spyder General Discussion Forum and read the second Sticky thread, the Do's and Do Nots. There is a wealth of very good information in that thread, particularly if your are coming to Spyderdom from the two wheel motorcycle world. Next, take the time to read your Operator's Guide thoroughly. Again, there is a lot of good, every day information about your machine in it. Lastly, if you received a video disc with your Spyder, watch it -- for your own personal safety.
    As others have said there's a ton of information on this site and a great bunch of ryders who do their best to provide accurate information and answers to questions.
    Have fun, be safe!
    May 2011
    Charleston,SC
    Sofia and I will be there on the 20th(black currentRTL,and a pearl whiteRT)ether at the beaver bar or suck,bang,blow
    Sep 2012
    Junction City, KS, USA
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Default Welcome aboard
    Don't forget to read the very informative post:
    http://www.spyderlovers.com/forums/s...-Spyder-owners
    Lots of great information for all of us.
    Don
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    May 2017
    madison heights va
    Thanks to all of you. looking forward to learning this macine.
    Faribault, MN
    Welcome Steelerman! I'm wondering if your bike doesn't have the tire pressure sticker under the seat when you open it up to fuel it? Did your's come with the owners manual underneath the Front Trunk liner. Mine was tucked in a plastic protector, right under the battery door in the frunk, but in a slot hidden by the Frunk liner.....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Apr 2017
    Sierra Vista, AZ
    Default Foam hand Grips
    Quote Originally Posted by Buckeye Bleau View Post
    welcome aboard!
    Joe
    Do those grips fit over the stock ones for the heated grips and can you still feel the heat with those on over the stock grips?
    Quote Originally Posted by DesertRider View Post
    Yes, they fit over the stock grips and you can feel the heat from the grip heaters although it takes just a bit longer for the heat to get through the foam grips.
    Mar 2017
    Star, Idaho
    Congratulations and welcome.
    Quote Originally Posted by tobor9 View Post
    You guys know the friendliest places to hang out!
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
