Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Quote Originally Posted by gazunni View Post
    I am starting to look for a trailer in the next month, so whenever you can give it a whirl, it would be appreciated.
    I'll provide you an update this week with photos showing the Spyder RTL on the trailer with hitch on...we'll see what happens!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
  2. #27
    Jul 2008
    Natchez, Ms
    I have an Aluma 6810 HT
    It tilts
    Will be transporting my RTL with trailer hitch this Thursday. Will try to remember to take and post a picture.
    Cappy
  3. #28
    May 2010
    South Portland, Maine
    Default hello
    The spyder set-up that mike is talking about works. My 2012 spyder was on the trailer, it did not move.
    The strap that goes over the center of the rear tire, and under the spyder and secures to the front of the trailer. The strap does not touch your tupperware.
    Deanna
    Nice meeting you at meeting in Vt yesterday Dave C.
  4. #29
    Jun 2013
    Woodbury, MN
    Default Pictures for you - loaded the RT today on the Droptail Trailer
    Quote Originally Posted by Jim&Teresa View Post
    Yes, it will fit with the hitch on. However, the end gate does not remain vertical as it has several positions in can be locked in. It's at a slight angle backwards in the first hole from vertical. I just installed the hitch on my Spyder RTL and wanted to know this as well - I hope this helps you!
    Some pictures from today for you:
    Pic 1: Loading RT on Droptail Trailer with rear part of trailer hydraulically lowered
    Pic 2: RT on trailer, still rear part of trailer lowered
    Pic 3: RT on trailer, rear part hydraulically raised and locked
    Pic 4: Rear end gate raised and one hole from vertical position (normally vertical without hitch bike), shows clearance to hitch's mud flap
    Pic 5: Another clearance shot showing where the rear end gate is in relation to the hitch's mud flap
  5. #30
    St. Catharines, Ontario
    Why is the wood necessary?
  6. #31
    Jun 2013
    Woodbury, MN
    A precaution so I don't catch my bumpskid on the rear gate ramp since my driveway is uneven. It pays to be careful when loading. .....good luck with your trailer purchase - there are a lot of good trailers out there.
  7. #32
    Mar 2017
    Minnesota
    Been following this thread and am confused on how people tie the bike down on the trailer! I have a flat bed aluminum trailer with single ramp and I have a F3T. I usually go up to the local school and drop the ramp down on the curb and the bike loads and unloads real easy but not sure how I should tie it down!
  8. #33
    Sep 2016
    Clifton Springs, NY
    Quote Originally Posted by I-Day View Post
    I have an 6x10 Aluma enclosed trailer and I use a ratchet strap through the rear tire and another ratchet strap up front a-arm to pull it tight. Have been thinking about getting some E-Track and run a strap around the front tires.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
  9. #34
    May 2013
    Indiana
    Quote Originally Posted by wrb3004 View Post
    Erickson Mfg has a wheel chock and tie-down strap kit. You can also by 4 pre-cut 2 slot E-track pieces and then just by the over-the-tire strap.
    2021 Marsala Red Metallic RT Limited
  10. #35
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Trailer
    Quote Originally Posted by retread View Post
    I have an Aluma 7210bt, with the 24 inch side rails, and a bifold ramp, the front section of the side rail is solid, think "rock guard". Cost was around $2500.
    john
    So does the bifold ramp still a 4 feet ramp, is there loading issues?
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
  11. #36
    Jun 2013
    Woodbury, MN
    Default Always strap it down
    I always ratchet strap down the Spyder on the trailer when travelling - two straps with protectors through the front wheels to frame of trailer. One strap on back tire with protector sleeve. I purchased the Droptail ratchet straps when I bought the trailer and they are very good! The only time it sits on the trailer without it being strapped down is when it's parked and just sitting still on the trailer.
  12. #37
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Quote Originally Posted by cyclekid58 View Post
    I haven't measured it, but I'd say between 5 and 6 feet when opened.
    john
  13. #38
    Had a similar problem with bumpskid and found if I lower the rear shock air pressure and sit on the passenger seat when loading it went on fine.
  14. #39
    Very Active Member johnnyg's Avatar
    May 2010
    Ocklawaha FL
    We bought the 18' from Shadow trailers in Ocala Fl. We have pulled it with our Dodge Journey with the RS and St on it, without any problems. Now we have 2 F3L and we are now pulling it with our Dodge 1500. We had it up in the Mountains without any problems.
    We were trailing in WV and Eastern KY. It came with 3 ramps, two of them are under the trailer in front of the front axles, the 3rd is like the bulk head of the trailer (front). It only takes about 20 min. to load or unload. We will have it in Quebec if you want to see it, we will be staying at the Best Western at Drummondville. John and Carol
    corbin Lamont cut seat with back rest, graphic gator,Chrome grips, trailer hitch,buttler mug, two brothers exhaust, painted center fender strips. center brake light, Led lights, tricLed fender lights
  15. #40
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    That is an excellent question. We used our trailer a few times last year with our 2014 RTL without a hitch! We now have a hitch on the bike. I have not had it on the droptail with the hitch on the Spyder yet. I will have to check this out!
    Worst case is, remove the hitch which is not too hard to do.
    When do you need to know this as we can get our trailer out next week and check it for you if that would help....it will take a little bit to do, but am willing to check for you and would like to know myself what options I have. I'm thinking if I put on my Spyder RTL on the droptail trailer, then I don't need my hitch on as will not be pulling my trailer with the bike! You'll need a much bigger hauling trailer if you want to haul both the bike and its trailer.
    ,oops I see you were able to fit it on from a later post.
    Or maybe just measure to see. I see you got this version Drop - Tail "Two - Up" Cruiser / Sport Bike Trailer, model number: 03-DCT2200-02instead of Street Pro 2200 PowerSport Utility Trailer which shows an RS on the trailer. Why? Does look like yours has more features though.
    Last edited by TicketBait; 05-10-2017 at 07:23 PM. Reason: saw you answered the "fit?"
  16. #41
    Jul 2008
    Natchez, Ms
    Default Here is my trailer
    Trying to post the pictures. Seems like they are here now😆
  17. #42
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    I just bought a Triton AUT 1272B (bifold) I will check out loading the Spyder, bought it to haul my SXS? I use something called a soft strap hauling the SXS, it's a strap with loops on each end that keeps the ratchet binder hooks away from the machine at your tie down points.
    2016 RT Limited , White
  18. #43
    Sep 2014
    Post Falls Idaho
    Default Trailer
    Quote Originally Posted by Jester View Post
    Does your frunk hit the bed in any way when loading due to the deck angle?
    2014 RT-S,
  19. #44
    Jul 2015
    South TEXAS
    Default Aluma Tilt Trailer
    We have an Aluma tilt trailer we use to haul our Spyder - the whole deck tilts [the Spyder nose doesn't drag loading or unloading].
    Tilt the deck, ryde the Spyder on, the deck tilts back level and locks - then tie it down and drive away. I can load and unload the trailer all by myself!! It's a breeze.
    We bought it in Litchfield, Illinois at Midway Trailer Sales; model #7712 HTILT.
  20. #45
    Aug 2016
    South Dakota
    Default Aluma TK1
    Has anyone used the Aluma TK1? I am considering one to haul my RTL behind the fifth wheel. I saw a video of someone loading a Spyder on one but I don't think it was a RTL, worried about the front cowling.
  21. #46
    Mar 2017
    Myrtle Beach, South Carolina
    Default stinger folding motorcycle trailer.
    I was looking into theStinger folding motorcycle trailer, they make one specifically for the Can Am Spyder but it does not have a rock guard on it.
  22. #47
    Mar 2017
    Default Stinger, Can Am Spyder Trailer
    Here is the website for the trailer.
    https://www.stingertrailer.com/produ...pyder-trailer/
  23. #48
    Active Member NewYorkSpyder's Avatar
    Feb 2016
    Schenectady NY
    Default 7210 Aluma
    This is the setup that I use only tie off the front doesn't move at all, no scratches on wheels (straps thru socks). Towed for many miles this way. Bi-fold ramp works great.
    2019 Rally , GMUltra Violet
  24. #49
    Apr 2012
    Florida
    We have a Forest River 7X12 enclosed aluminum trailer. It weighs 1300 lbs.. Great for hauling the Spyder. And the Spyder is out of the weather, safe from problems when parked. We were parked right behind Mike T at the BWCH+ when all the problems happened. Tom
    2020 Petrol Blue Metallic RTL
Tags for this Thread
