![Quote](images/misc/quote_icon.png) Originally Posted by OverHillAndDale
Just cancelled my previous order and re-ordered the part from PitBull. They had 30+ in stock.
I just called them and one on is way.
![Quote](images/misc/quote_icon.png) Originally Posted by Doc Humphreys
Just talked to Pitbull Powersports at 418-863-1418 and they still have several of the BRP kits available.
Ok call me a moron, I went to the Pit Bull Powersports site, typed in 219800412 into the search window, 219800412 not found, went to oem parts search, selected CAN-AM (Bombardier) no model number and went to the part number window and typed 219800412. Still not found.
Can someone give a direct link to the exact page I can order from? Please? ![Gaah](images/smilies/gaah.gif)
I think the area code is 417 not 418.
![Quote](images/misc/quote_icon.png) Originally Posted by TheCajun1957
He told me they removed the part from online ordering. So give pitbull a call. I did and he is sending me one.
![Quote](images/misc/quote_icon.png) Originally Posted by Biggdogg22
Just ordered mine tonight. I got the Idler from Florida Power Sports via Amazon and the bracket and bolt kit from Doc Humphrey. Hope I get them before the end of the year 2016.
Reggie
Received both parts today 12/28/2016. I will install Saturday or Sunday.
On the way !!
Got em!!! 1/2/2017
I installed mine on Friday. Too much rain to go for a ride, though.
The installation video is a must-see. The actual installation is a breeze, but the video shows the way the parts go together.
Installed mine - 2012 RT SE5
STill cold here in Indiana, good time to install the Doc Humphries belt tensioner. It was easy. View the video.
I am not comfortable working on the bike, but every time I do, I feel better and better.
Can't wait for warm weather to try out.
I'm pleased with it!
I rode my Spyder into work this morning and forgot to check how well the new tensioner is working! It must be working well, 'cuz I hit 75 mph and it was not vibrating at all!I
Thanks, Bob! Everyone is saying that they cannot believe the difference. I installed a kit #3 on a 2012 RT yesterday and the ryder was very, very happy. Said it removed 80-90 % of his total vibration. He also didn't notice the little buzz from the outer ribbed belt.
Finally got mine today from the post office here in the U.K. Due to customs & the import tax required before they can release it
i have already have the BRP one with Doc's adapter plate fitted to my RT
So pleased with it, I decided, I wanted to upgrade to the new one Doc has done because I have no intention of changing my 2015 SE6 RT for some time
As usual with all his products it is excellemt quality
I have polished the arm, Only shame is that it will be hidden under all that tupperware
Thanks Doc - Just looking for you next RT upgrade
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
![](signaturepics/sigpic6047_5.gif)
Confused I am
It is a rather long and convoluted story that has been adapted and changed multiple times.
I started by installing the F3 idler on my 2017 F3S Daytona. I got to thinking about it and wondered if it could be adapted to our 2014 RT. I did some tests and finally came up with a prototype and gave it a try using the BRP kit. I couldn't believe the lack of vibration on the RT. In fact, having both the F3 and RT I could tell that the F3 idler actually worked better on the RT than the F3. I was concerned about clearance of the gas tank and the tensioner (which was the reason BRP did not would not use it on the RT. By removing all the air out of the airbag, and with the tupperwear off, I simulated a complete rear suspension failure and with the tire setting on the inner fender, we still had 3/4" of play from the pulley to the tank.
I then started to work on a vibration damper that would be more durable that the idler kit for the F3. We have finally got it dialed in with a total of 5 different kits and the original adaptor kit. This works for any aspect that someone wishes to do. Most everyone has this link already, but I will post it for those just getting up to speed.
In everything we do at Roadster renovations, we have tried to use the best quality items available so that everything we make makes our bykes perform better and work better than original.
Here's the link: http://dochumphreys.wixsite.com/road...amper-products
Doc that link only had 2 not 5
Sent from my VS990 using Tapatalk
14 RT-S , Stock Large brake pedal White Pearl
![Quote](images/misc/quote_icon.png) Originally Posted by NM Wrench
Can't use a smart phone. Sorry. Big 'puter works fine.
Hey Doc!
If you need one: I've got a spare "Smart-Enough" phone that you can use! ![Big Grin](images/smilies/biggrin.png)
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
Hey Doc!
What I need is to figure out how to display the site on the smartphone. I will eventually call the site people and hopefully they will figure it out.
Doc's upgraded RT Belt Vibration Kit
Fitted my upgraded one from Doc for my RT
i managed to remove the BRP one by taking it off Doc's RT adapter plate (leaving the adapter plate in place) so only the 2 bolts to remove
I found it was easier to fit the new one on - do the bolts up enough to hold it to the adapter plate then connect the spring through the arm and then tighten the bolt once I was happy with the alignment
Because the arm is fitted below the adapter plate and it is metal to metal I decided to put some rubber to help add a dampening effect from the arm to the adapter plate
The rubber is only 2mm thick and does not effect the clearance between the arm and frame
Only went for a test ride but I could not detect any vibration in fact it is even better than the BRP one it replaced
Eddie Sheppard
Poole Dorset UK
Is it going to do any harm not "fixing" the vibration? I went on my longest ride on the interstate the other day while I found it annoying when it did happen it I usually just had to slow down or speed up to make it go away...mind you I didn't even know this was actually known issue until today when I happened to see a thread on the vibration issue. I was going to call my dealer and ask about it. I think that since I was able to kind of work around it I'd just let it go...but if it's going to cause issues letting it vibrate I want to fix/remedy the issue.
Also...will the fix cause any premature wear on the belt or any other unwanted side effects?
Doc, I had your tensioner installed on my 2013 RT LTD - picked it up from the dealer on 28 April and had a 65 mile ride home to check it out. Yesterday, I rode with the Maryland Spyder Web, and got to give it a real workout - I have to ride 65 miles, each direction, to and from the meetup location, mostly on highways. I was running between 55 and 80 MPH and never had any perceptible belt vibration at any speed. It works great. I'm a believer!
Best thing i ever put on my bike the dampner what a difference
