Results 1 to 25 of 36
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    Default Foam Grip Installation
    Foam grips seemed like a good idea for my F3T...until I tried to install them. The instructions seem to indicate they would slip on but getting them over the raised edge seems impossible. Maybe there's a 'trick' to make it happen?
    Thanks!
    Dec 2012
    Murphy, NC
    Default GRIPS
    Spray water or Windex inside the grips. They will slide on much easier.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Or use hairspray, it'll be slippery at first and then stick.
    Bob S
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    Hand Sanitizer. Really slips great when installing, the alcohol content makes it evaporate when you're done. Really slop it on...
    The instructions with my foam grips recommended hand sanitizer. I couldn't believe how easy they went on with it.
    Dec 2015
    NE Ohio
    for the hand sanitizer option. Worked great for me on several installs.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    The instructions say use hand sanitizer. I installed mine using hand sanitizer slipped on with no problem.
    Apr 2016
    South Central PA
    +1 for hairspray. Been doing it that way since the 60's.
    Feb 2017
    Fort Myers, FL
    These things must come in sizes! These are not 'sliding' anywhere. Getting them over the rigid end cap would be a major accomplishment. I was thinking maybe you guys were using a hair dryer or some such?
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default Foam Grips
    Quote Originally Posted by nealperkins View Post
    Neal, I have seen some foam grips that have a smaller inside diameter That won't fit over Spyder Grips,
    TRY ( Grab On Grip Covers ) They work well for me..Just Google that brand name
    Freebob
    Harrington, Australia
    Neal, you don't need a hairdryer. Put some liquid soap or one of the other recommendations on your fingers and run it around the complete insides of the grips. They will slide over everything. If that does not work, Freebob may be onto your problem above.
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2017
    Central Texas
    +1 hand sanitizer worked for me. Use a very liberal amount, never to much just not enough. Don't be afraid to slop so much on the inside of them that they are dripping wet.
    kansas
    Air compressor,it expands them and they slide right on.
    Put them on or off in 2 seconds with no mess and reusable.I don't use glue.Works real slick.
    This is for the grips but same concept.
    https://www.youtube.com/watch?v=emUSZKEDLng
    Invalid Emails
    Aug 2010
    Buy foam grips from Spyderpops
    His are made to fit Spyders. Great quality and they
    work great
    Feb 2017
    Fort Myers, FL
    Yes, these are the Grip-On from Spyder Props.
    The problem seems to be the outer ridge, of the rubber grip, being substantially larger than the body of the grip. I think the various lubricants will work fine if I could clear that larger ridge!! Do all the grips have this ridge?
    Mar 2015
    Advance, NC
    I lost man points and read the directions, hair spray.
    Neal, I've got Lamont's bar end and helmet locks on mine.
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2017
    Fort Myers, FL
    ​I 'just' had a terrible thought...are these grips supposed to be a 'replacement' grip? Meaning the rubber grips are supposed to be removed first??
    Hahaha....no...they go over your current grips.. do your grips look like my photo above?
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2017
    Fort Myers, FL
    Sorry, I don't see a photo.
    I'm going to post a picture tomorrow myself.
    Thanks!
    Thanks!
    The photo in post #17 Neal
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    As well as the soap/hand sanitiser etc. try:
    Turning the part of the tube inside out, perhaps a couple of inches. put the rolled edge against the bar end relatively hard and put a bit of the tube over that wide lip so it's partly on. Then try rolling/pushing the inside out bit forward over the rest of the lip, do it bit by bit from that point where it already overlaps
    Aug 2015
    Canton, Ohio
    I agree with most others, I got mine from TricLed. All I did was squirt a little dishwashing liquid on the inside if the grip, or put it on the bike grip, no matter, and they slide right on.
    Regardless if it is dish soap or hand sanitizer, wait a day before you ride, they may turn on you. Easy, peezy, lemon squeezey!
    Joe
    Apr 2017
    North Central Florida
    Quote Originally Posted by Buckeye Bleau View Post
    And since the subject came up:
    Do NOT use grip cement or other glue on foam grips.
    It tends to dissolve the foam and makes a real mess.
    Houston
    Yes.
    They install over the ridge. They will stretch enough to install.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
