Originally Posted by
eddieshep999
On my 2015 RT 2015 SE6 model I had several LED's fitted by the dealer this included fender indicator LED's Rear fender running/brake lights, the High mounting Brake light and the rear saddlebags running/brake lights
All these were from established Spyder Led suppliers
When I used the brake the Radio would cut out and only static could be heard
(foot off brake radio returned to normal)
The dealer tried to shield the antenna but the problem continued after disconnecting each of the LED's and testing the problem was resolved by only having the saddlebags Led's as running lights removing the braking function of the LED's, it was that breaking function that somehow caused the interference
Simce then my Radio has been fine
Not sure if it will help but it may be worth considering having the dealer investigate it
Let us know what resolves your problem as we all benefit from the knowledge of others
