It was a good thing that you were @ home, when you got the DESS error. Let us know what you decide. Did you see the thread" DESS KEY CODE AGAIN!!!!!!!!!!!!!!!! posted by me( Deanna777)?
It is a long thread, it has some great info. and suggestions. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
![Quote](images/misc/quote_icon.png) Originally Posted by Deanna777
Yes, I just did a search on the DESS ERROR and that thread came up first. I only read the first few posts. I thought only RT's got that error.
2017 F3 Limited
If you get that code and it goes away, and runs fine the next time, whats the chances that I may get stranded somewhere soon? Like in Springfield in the middle of a thunderstorm? Now I am having second thoughts about going.
2017 F3 Limited
I could take my wifes Harley.
2017 F3 Limited
![Quote](images/misc/quote_icon.png) Originally Posted by AY4B
It is your choice. Good luck! Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Mine started last week with that error and got worse the second time I parked the bike. I would not take the chance..Have it fixed
Parts are available and can be done in a few hours if it only the DESS module. If its the switch too that's a bigger job
Schedule the repair with Pitbull, go to the event and let them fix it. You may get stuck, but most times, everyone gets a bunch of get out of jail free restarts.
Ill call Richardson Motorsports tomorrow and see what they say. It is out of warranty but since this is an issue with these bikes , maybe they will just fix it.
2017 F3 Limited
Last year when I went to Spyderfest, I stayed at the Econolodge. That is where I met Blueknight 911. He had got that error at the hotel had had his Spyder all torn apart in his hotel room.
2017 F3 Limited
it is covered under the B.E.S.T warranty. Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Yep, he did have his spyder torn apart , and the next morning he had his spyder at Pitbulls, with out the frunk, and got the latest new dess module. That is mike(Blueknight911). Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
I have had the DESS module replaced twice( see my thread) and switch replaced once both under warranty. I haven't had the DESS error show up. The dess module/and the switch are under warranty. Be sure that your dealership has the parts there.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Latest DESS module part module #710004916.
AND you have to remove the metal Ferrite ring off the old module and put it on the new module. BRP does not have them installed on the new module ![banghead](images/smilies/banghead.gif)
You have to remove the contacts from the connector to get the Ferrite ring off
DESS CODE
I was planning to go with Spyder Ryders of East Texas. we have 20 signed up and some are trailoring. If worse comes to worse, I will have help close by.
I just went out and my bike is starting every time now. No error message......BUT.....
2017 F3 Limited
I'm going to Spyderfest
Just had the 5th occurrence of a DESS error. Goes back to the shop when I return from Spyderfest. Module replaced 3 times, but who is counting?
See everyone soon.
Don
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
Nope,
All Spyders share a similar system. The RT has had more problems reported with it mostly because of their larger numbers and the F3 did not exist until a year later.
Also as reported above, yes, I can turn the DESS off for you if you wish and the problem will be gone permanently. I am in NW Houston.
I had the issue on my 2014 ST and had the module replaced under warranty. I believe it may have happened due to where I parked but I raised enough of a stink that BRP replaced it.
That was almost a year ago and I haven't had a problem since.
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
![](https://www.spyderlovers.com/forums/maps/map.png?states=NJ.NY.CT.MA.VT.PA.MD.DE.VA.WV.NC.TN.KY.OH.IN.IL.MO.AR,NH)
Mine had the error twice one day last week. Once it came on in the middle of cranking. I suspected the battery might be going and put a new one on it. I never got the error again after replacing the battery but the warranty runs out next month so I decided to have it looked at.
I called Louis Powersports in Greenville and they said it would be over a month to get it checked out! I called Freedom Powersports in McKinney and they got it in the same day. It is there now waiting for the ignition switch and D.E.S.S. module to come in. Hopefully parts will be there tomorrow.
2014 RT Limited, Cognac (Wife's) Hand Brake, Heated Comfort Seat, iPhone Cable in Glove Box, Baja Ron Swaybar, Spyder Pop's BumpSkid.
2014 RT-S, Cognac (Mine) Tri Axis Bars, Comfort Seat, BRP Backrest, iPhone Cable in Glove Box, Baja Ron Swaybar, Spyder Pop's BumpSkid, Spyder2go Drink Holder.
![Quote](images/misc/quote_icon.png) Originally Posted by jcthorne
Nope,
I just sent you a PM. I believe this is the best option.
2017 F3 Limited
It looks like Ill be riding to Houston. ![pray](images/smilies/51.gif)
2017 F3 Limited
Both the DESS module and the IGNITION switch need to be replaced in order to permanently fix the problem.
Other then having the unit shut down entirely via BUDS.
AJ
![Quote](images/misc/quote_icon.png) Originally Posted by Don in E Texas
See everyone soon.
Don
![](signaturepics/sigpic17544_7.gif)
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
See everyone soon.
Don
Don,
What is the dess module part # that you have?
The newest dess module part # is 710004916.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Maybe your dress is on too tight
