Results 1 to 7 of 7
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    Default In need of new tire
    I am in need of a new rear tire. Any shops in the KC area replace with tires other than Kenda?
    Mar 2015
    NE Kansas
    As far as I know and have experienced, Advantage Powersports and Renos both will only replace Spyder tires with OEM Kenda. I have had work done at both dealer service departments and find them friendly and reliable. I don't know of any independent shops that will work on Spyders in the KC area but I am sure there may be some. Good luck.
    Jun 2014
    Kansas
    Thanks. That is what I was afraid of. New Kenda is still better than worn Kenda.
    Jun 2017
    Independence, MO
    Default THE rest of the story.....
    Quote Originally Posted by Scotts8826 View Post
    So where did you end up going and how much did it run you?? New owner but the handwriting is on the wall as far as the rear tire is concerned!
    Active Member bayoumanPIBE's Avatar
    Columbia, MO USA
    Default If you feel like a drive...
    YC Powersports in Columbia, MO is more into Spyders than they used to be...I just purchased a few things from them. They maybe able to help.
    Life's short...Play it by ear and ryde!
    Active Member wd8ajj's Avatar
    Las Cruces NM
    Just had mine tires balanced at Big O tire and they stated that whatever tire you wanted to install they could get and install.
    Might talk to your local BigO tire store or whatever its called in your area and see.
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Did you have the rear or both fronts done? Spin balance or the old bubble way?
    Last edited by BoilerAnimal; 06-08-2017 at 09:54 PM. Reason: Corrected Auto Correct!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
