Results 1 to 14 of 14
    Apr 2016
    Alberta
    Default Traction control
    Any info out there yet how to turn the traction control off on the older F3's like the new 2017's have? From what I've seen, the 2017's don't have any new buttons my 2015 has so it must be just soft wear, the dealers don't seem to know anything about it.
    Jun 2010
    Las Vegas
    Isn't that feature only available on the Daytona model?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2013
    Oz
    It's on all 17 f3s.
    I don't think brp have any plans to retrofit to earlier models. Might be just software/buds settings, but doubt it'll be available. So I guess husband has it on his 17, and I miss out on the 15.
    To be honest, I don't care a bit.
    Currently; it can't be done...
    Will they offer it as a software upgrade on the older bikes?
    You'll just have to burn up your tires in a straight line...
    Or trade for a 2017!
    Dec 2014
    Graham Tx
    Default Traction Control Buttons and Gear Ratios
    Does the 2017 F3 Limited's have a traction control button? I have
    not found one on mine.
    On a different subject and if memory serves, my 2015 F3S rpm at
    75 mph was somewhere 4500 +/-. My 2017 F3 Limited rpm at 75 mph
    is at 4000 +/-. Called a friend that has a 2014 RT and his rpm/mph is
    about the same as my Limited. Has anyone else compared rpm/mph?
    I do know that the 2015 would smoke the tire a lot easier.
    I must admit that I do like the cruising rpm. I am just curious!!
    Thanks for your input.
    Dray
    Sport Mode isn't available on the Touring or Limited Models.
    Apr 2016
    Alberta
    Quote Originally Posted by Dray View Post
    Dray
    i think the sprocket is a difference size on the F3S
    You can start by snipping some wires. But, I don't recommend that. It's there for our safety, so I will tough it out.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by BFB View Post
    That's incorrect. F3S and F3T North American version have the same size rear sprocket. The 2017 F3 has a smaller rear sprocket the same as RT, ST and GS/RS models, all years.
    not found one on mine.....
    Do ANY of them have a Traction Control Button?? Those I've seen didn't have one, & I was lead to believe that ALL those with the Sport/Hooligan mode feature used a Looong press on the Mode/Eco button to select Sport Mode...
    Jul 2011
    Sport mode indicator is item 11.
    Instructions to engage and disengage.
    United States
    I've only had my Daytona in it once to see if it would work. I'll try to snap an actual pix of it engaged and post it....
    United States
    Default 2017 F3S Daytona "drift mode" display
