Airhorn
Has anyone installed an airhorn or something louder then stock horn need to get drivers attention
Lots of people have and it's a relatively easy task.
Many people use the Wolo Bad Boy horn or Seibel (you can find these at many auto parts stores) and there are some others. You can install the new horn on the same mounting point as the current horn.
Although many people don't use one, you should install this using a horn relay, also available at almost all auto parts stores.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!![wink](images/smilies/icon_wink.gif)
![](https://www.spyderlovers.com/forums/maps/map.png?states=AL.GA.FL.LA.MS.TN.NC) ![](https://www.spyderlovers.com/forums/maps/map.png?states=AL.GA.FL.LA.MS.TN.NC)
I just installed a Stebel with the relay. Stebel says their horn can use up to 20 amps, and therefore recommends the relay to prevent electrical damage to the bike's horn button or other parts not designed for higher power. YMMV.
And the difference
is AMAZING. The Strobel is MUCH louder than the wimpy a$$ stock horn. Its also louder that the WOLO " bad boy". I have both, installed with relays and have done the side by side comparo.
Wimpy a$$ horns cause::::::::::::: Kaos
2014 RTS in Circuit Yellow, farkle-ing addiction down to once every few months. ECU FLASH IS GREAT. ![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.ID.MT.NV.OR.SD.UT.WY)
Please throw another vote on the "Stebel Nautilus" pile from me!
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
![](signaturepics/sigpic20397_1.gif)
See the trumpet air horns on mine in my sig photo. They work, get people's attention really good, and look good, I think.
![](signaturepics/sigpic14672_7.gif)
Thanks Doc
for posting video, I'm definitely getting one, the original is a joke.
![Quote](images/misc/quote_icon.png) Originally Posted by Ramg66
Nowhere as weak a meep as the one in the Nissan Versa I have rented right now!!
Bought my Wolo from Spyderpops. Good price, easy install, very pleased.
"They can hear me now!"
thehawk
In theory, there is no difference between theory and practice ... in practice, however, that's just a theory.
