Results 1 to 18 of 18
    Mar 2017
    Iowa City
    Default Ohhh. That wind.
    So I've been breaking in my spyder..this past weekend I got 280 hard fought miles in so now I have 500. That wind though!!!! Whooo!!!! That sure is something else on one of these!!!! There was a couple times that it felt like I was gonna get blown into the ditch!!
    If you tuck your knees in tight against the "tank"; it'll help to stabilize you on top of the bike, and keep you feeling much more comfortable in those situations.
    Thinks out loud
    Apr 2012
    Smile Stability in the wind
    You may not realize it but best guess is that driver inputs were causing a majority of the jitters. Next time, and there will be many of them. Loosen your grip, keep as much of your body out of the airflow as possible, and see if you notice a change in handling.
    Mar 2017
    Iowa City
    I've been working on loosening my grip. It was really tough especially yesterday, I guess it's just those old motorcycle instincts kicking in and gripping on for dear life. Haha.
    Over control will give the a feeling that it has a mind of its own. You will get better with a few more miles.
    White knuckle gripping will put unnecessary input into the steering. Try to pretend that there are eggs between your hands and the grips. Do not break the eggs. A gentle push/pull on the steering, lighter grip, and you will be amazed at how the begins to behave.
    I also suggest reading the thread on Do's/Don'ts. There is a lot of great information in there.
    Gunny Ermey said it well:
    He has such a way with words!
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Default Wind
    I was on the Spyder in NW Iowa in the wind also. The gusts are the worst, but a light touch on the handlebars kept in on track. The two miles of gravel road, from where I store it to the highway was the worst. Just kept it slow and steady and did just fine. Have fun riding.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I mainly just rest my palms towards the outer ends of the grips when cruising along. sometimes I just lay my wrists on top of the grips. rarely do I wrap my fingers around the grips. I use my palm and thumb to control the throttle most of the time. its easier to steer these things with your palms than it is to grip the grips.
    Oct 2013
    rome new york
    yep the lighter the better. Like touching well never mind u get the idea
    Nov 2014
    Rural Hall NC
    I have found that the wind blows me around, not the bike. The unexpected gusts will really send me flying. I get knocked sideways but Cocaine rides straight and true.
    Sep 2012
    Junction City, KS, USA
    The lighter touch comes with practice.
    Also, if you're coming from 2-wheeler experience, remember the in a cross-wind you have to steer into the wind on a Spyder.
    Mar 2017
    Iowa City
    Quote Originally Posted by Bam Bam and Pebbles View Post
    You know I was getting knocked around quite a bit and that's why I had the death grip which in turn made it all just worse.
    Dec 2016
    Boise ID
    Quote Originally Posted by Gallam03 View Post
    I know the feeling, A while back and got into some stiff cross wind (40 MPH gusts) that got my attention real fast.
    I to am just getting used to the change in the way 3 ride over the 2 I have road so many years but things are getting better,
    I found that the knees thing helps and the lite grip also works for me (to a point),
    Now I am waiting to see how it is after I changed front tires and the sway bar it does feel better but have not road in side wind again like that.
    RELAX RELAX RELAX Ya right sometimes its hard to do when have part of the seat up your (never mind) and your butt is sending signals to your hands.
    Guess it comes with miles so it off for some more fun + or -
    Mar 2017
    Iowa City
    Yeah I'm bone stock right now. I see lots of people upgrade their sway bars, front shocks, add stiffeners
    , etc...It's on my wish list
    Jan 2015
    southern WI
    The upgraded sway bar will help. Also don't forget the simple stuff. As basic as it is, tire pressure is big on the Spyder. make sure your fronts are the same pressure. Use a good digital gage to check em with. Start with 18-20 psi in the fronts, and about 28 in the rear and see if it helps. Loosen that grip, and grip a bit with your knees. Give it a while and if it still seems squirley, an alignment might help as well. If you have a high windshield, lower it down a bit. Those things become sails in the wind
    2016 RTS , Pearl White
    Dec 2016
    Boise ID
    Gallam
    I just got back from my 100 mile ride and on the Fun + or - scale I would have to say definitely on the Plus side Way on the plus side again I had some side wind just not as strong as before BUT the Spyder ran as if it was on rails, I know a major part of my problem was me but it also helped with the new Sway Bar and getting rid of the stock tires on front, Next Laser alignment is in order and if it makes near the difference I have had so far I will just set in the rear seat and point it toward home, Will may not to that extent but close.
    BTW I am just over my first 500 miles so it does get better, I did as everyone has said the knees tight to the bike and kept telling my self to stay relaxed
    Dec 2016
    Boise ID
    Quote Originally Posted by bmccaffrey View Post
    I kept that in mind to day and I have to say with the lite touch she responded very nicely .
