Need used hitch
Old Geezer on fixed income needs a resonably priced hitch and plug n play wiring harness for 2012 rts sm5 and while I'm at it could use a connector for an ipod. Thanks in advance to all the good people on here......David
need used hitch
David,
Have you ever considered buying the show chrome and doing the wiring yourself; it isn't too hard once you identify the wire colors for your brakes and turn signals.
Al
2018 F3-T
Thanks for the advice
Howdy,
I was going to do that but got incredibly blessed to find a hitch and wiring harness on cl.
Now the only thing I need is a connector for my i-pod that goes in the rear trunk,I have heard that there is an aftermarket one that will work, does anyone happen to know a part number if this is true? If is there someone that has a brp one.
Thanks again for the post.........D
Originally Posted by dwpnomad
Howdy,
There was a change in the connector in 2012. PM Bob White, Finless, and he can help you figure out which one you need. You'll be best off to buy the BRP one. You can probably find one on eBay.
