Results 1 to 20 of 20
    Oct 2015
    British Columbia
    Default SPYDER HORN UPGRADE
    I was thinking of changing out my stock horn on my 2015 Spyder. I would like a deeper tone. I don't need a air horn. I'm looking for simple installation ( I know, Aren't we ALL). Anybody got information on this.
    Doug
    Active Member Rawhide kid's Avatar
    Jun 2015
    Goodyear, AZ
    Default Wolo
    Wolo was very easy to install. Lots of threads on this. Wolo (419) Bad Boy Air Horn - 12 Volt https://www.amazon.com/dp/B000F5DQWY..._wZDRyb5BBHDBC
    Rawhide Kid
    2014 Spyder RT Limited. Cognac
    Goodyear, AZ
    Wolo's Bad Boy, and Stebel's Nautilus are just like two peas in a pod... pick the one that you can get the best price on!
    United States
    This is what we put in. Very loud.
    I'm going to put one on the Daytona when I find where that sucker is..........:roflblac k:
    Active Member Marcy's Avatar
    Leesburg VA
    Default Wolo
    I got the Wolo from Spyderpops comes with mounting hardware and is simple 2 screws and 2 wires. Wires have ends already, unplug one, plug in the other. Great set up, no more beep beep. Great safety upgrade.
    2019 F3T , Blue
    Feb 2016
    Jupiter, FL.
    I have a WOLO. Plenty loud!
    Sent from my SM-G920V using Tapatalk
    Hey Doc!
    Thanks for making our MikeT famous!!
    (Mike... Hugs to your Bride!)
    Jan 2013
    San Diego area
    Red face WOLO horn
    I just installed one so simple I had to find something else to do to stay outside away from sister in law easy job 15 minutes or less
    Loving the RYDE
    SoFlo
    Junk yard, $5.
    Nov 2015
    Myerstown, Pennsylvania
    Default Other Wolo.....
    Has anyone tried these?
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Default Try this....
    Your local autoparts store. They have some louder ones similar to the stock ones easy swap....
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Check out the Wolo 619, same size as the 419 but a tone like a tugboat!
    john
    Nov 2013
    Central Texas
    Dumb me, I figured to save myself the trouble of installing a WOLO myself, and let the dealer-who-shall-not-be-named (I don't go there anymore) install it while the recall work was being done on my 2013 RTL. I supplied the horn, relay and in-line fuse. When I went to pick up the Spyder, I was presented with an invoice for 3 hours @ $99.00/hour to install the horn. I could feel the volcano in me ready to erupt, but kept my cool. I asked to speak to the owner of the dealership. I very calmly explained that there was no way it could possibly take 3 hours to install a horn. He offered to cut the labor time & price in half. I offered to call the DMV and report them for price gouging. He then offered 1 hour. I pulled out my cell phone, looked up on the wall where the required shop rates, etc. along with the complaint number for the DMV are posted, and started dialing. He then very quickly offered to wipe the slate clean and not charge me anything for the install as a "goodwill gesture" because I was such a "valued customer". I started to ask him why, if he was willing to do it for nothing, try to charge me for 3 hours labor, but I kept my mouth shut, walked away, got on the Spyder, rode off and never looked (or went) back. Amazing what some dealers will try to put over on their customers.
    Quote Originally Posted by oldguyinCT View Post
    The 2013 RT is a bear to install an after market horn in. When I did mine there were only two really good options I could see, add trumpets and squeeze the compressor in above the oil tank, or install something like a Bad Boy in place of the OEM horn. Neither option was a straight forward simple job! I went with the trumpets. I liked them so well I did the same thing for my 2014 even though there is plenty of room where the oil tank was in the 2013.
    Your dealer may have screwed you, but I would say nowhere nearly as bad as you think he tried to.
    Mar 2016
    Astoria, Oregon
    I did the same with the Stebel Nautilus. First farkle I added! Safety first.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Jun 2014
    People's Republic of NY
    Quote Originally Posted by Doc Humphreys View Post
    How did you get the panel off without taking the mirror off?
    Boerne, TX
    I had a horn installed at a rally. I don't know the brand but it looks like a Wolo.... It is not as loud as I expected as I have one on my Gold Wing trike and it is much louder. The installer did not install a relay, telling me it was not needed. Should I install a relay? Thanks
    Hi George!
    They usually need the relay in order to get their "singing voices" up to full song...
    Boerne, TX
    Thanks Bob. I will get one and put it on. It sure can't hurt.
    Apr 2013
    Little Elm Texas
    Ordered mine through Spyderpops, super loud.
    Sent from my iPhone using Tapatalk Pro
