Page 1 of 3 123 LastLast
Results 1 to 25 of 53
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    Default towing 3 wheels down
    I'm getting ready to start me retirement in my RV and I would like to tow my 2012 RT behind it.
    Is it possible to tow the RT 3 wheels down?
    I can make a bracket, I just want to make sure I will not hurt the engine and transmission
    Aug 2015
    central oregon
    The transmission needs engine oil pressure for proper lubrication. Get a trailer.
    Member HughT's Avatar
    Mar 2015
    Burlison, Tennessee
    Default Can Am Towing System
    I don't know if anyone has tried this system. Take a look at http://www.motorcycle-rack.com/CanAm_Tow_System.html
    It might be what you are looking for. If anyone out there has tried this, please let me know.
    HughT - US Army Major (Retired)
    Default WELLLLLLLLLLLLLLLLLLLLLLLLLLLL
    After advising DO NOT DO THIS ....... could you - yes if you removed the DRIVE BELT ..... But I can not think of any type of towing set-up you ( or someone ) could devise that wouldn't do something BAD to the front suspension ..... other than a front wheel DOLLY set-up !!!!! ..... But that would have to be custom made ..... so cost wise getting a small aluminum trailer is easier and cheaper in the long run............ Mike
    Default No....
    You can tow them to safety but if you are going to travel I would trailer it. I did see a lift (like motorized wheel chairs) on the back of a motorhome with a spyder on it but not sure how well that would work. I know there has been mention of towing but removing the belt so there is not drive to the engine but not an easy task to do each time you want to ryde.... Toy hauler or trailer would be best....
    Jun 2014
    south florida
    I was thinking of this setup and I even saw one once. The problem I have is that I have a 10,000 pound hitch that would support 1,000 pound tongue weight. The bike weighs almost 1,100 pounds. which is not a problem. The problem I see is that the bike is hanging very aft of the ball and bouncing up and down.
    Jun 2014
    south florida
    Quote Originally Posted by HughT View Post
    I actually like that.
    Would I have to remove the windscreen ever time I tow it?
    What about the front wheels, would I have to lock the handlebars?
    Jun 2014
    south florida
    The front tires on the scale are 650 pounds and the rear tire was 450 pounds.
    Mar 2015
    Burlison, Tennessee
    Default If I go with a trailer -
    I know that has been a lot of discussion about trailer size, what size is recommended for a RT?
    Consider a 6x10 trailer as about the minimum.
    Nov 2012
    North Las Vegas, NV
    Looks like the nose would be very close to the ground. I would get a nice trailer and be done with it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    Site Sponsor:http://the-ultimate-trailers.com/mot...-trailers.html
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Jun 2014
    south florida
    I was building a nice aluminum trailer with a tilt bed. Since I don't weld aluminum I was having the shop teacher weld it. I don't think it will be finished in the next two weeks. I will be back next January and finish it then
    Jun 2014
    south florida
    I'm going to make it with the back wheel a little lower. My front wheels are 2-3" higher than a normal RT since I changed the springs
    Jun 2014
    south florida
    The one that I'm building has a bed 6' X 10" which tilts, and then 3' upfront for an enclosed area (3X6').
    Very similar to the Aluma trailer
    Default 2 TO 3 INCHES
    Quote Originally Posted by ahh-cool View Post
    Really ..... so your ground clearance is now 6 1/2 to 7 1/2 inches ........ The people who did your front alignment must have been talented .............. jmho ...... Mike
    Aug 2015
    central oregon
    Really ..... so you ground clearance is now 6 1/2 to 7 1/2 inches ........ The people who did your front alignment must have been talented .............. jmho ...... Mike
    Setting the toe in with the laser will be the same but I'll bet there is more than a little negative camber. Negative camber will stick good in the corners but raise hell on tire wear. That much change in ride height can't be good for suspension parts. just another opinion.
    Oct 2007
    Min. trailer size is 6ft. X 10fyt. I know because I have a 5 X 10 trailer and it is 3" too narrow. Good thing I have a neighbor who has one the right size that I am borrowing next week to get my new RT Limited. Always a two wheel rider until this year.
    Jun 2014
    south florida
    I don't get it??
    They laser aligned it. I also raised the rear.
    It handles so much better. In a roundabout I can turn the wheel with one hand. I used to fight to do that
    Jun 2014
    south florida
    Quote Originally Posted by fjray View Post
    It's a much smoother ride.
    Oct 2013
    rome new york
    yep that's what u need to do
    Vermont
    Tow your 2012RT spyder on a trailer, behind your RV, tie your spyder down with a strap.
    Run the strap underneath the spyder ( so it wont scratch your tupperware) and on top of the center of the rear tire, secure it on the front of the trailer.
    Send a pm to Mike,( Blueknight911) he can help you. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default Trailer rails
    Whatever you do, DON'T buy a trailer with siderails. Unless you have a lot of clearance, it's miserable to load the bike. My trailer was four inches wider than my F-3 and it would take a half hour or more to load because you have NO room to turn the front wheels. I just removed everything above the load bed with a bandsaw except for the front bulkhead and the rear eight inches which support the tailgate and the lights. Things are much easier now. You also need at least a five to six foot ramp in order to keep from high centering as you load the bike.
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default This one works great for an RT
    [QUOTE=HughT;1227041]I know that has been a lot of discussion about trailer size, what size is recommended for a RT?QUOTE]
    From an earlier post of mine:
    Get the dimensions and literature: http://www.droptailtrailers.com/
    I use it for EITHER the Spyder or the Gold Wing. I must use the center position for the Gold Wing as it will not fit on the left or right side of the trailer due to length. We trailer our 2014 RT Limited with no problem with this trailer and it "noses" up in the V part of the trailer against our 20" stone guard (which is optional). The 4 pictures added at bottom were just a couple months ago....note that I do NOT transport with the cover on it. I only cover the Spyder when leaving it out overnight! Also, all the tie down straps were removed at this time as it was parked.
    We use a Droptail trailer. I really like that it folds and stores upright in the garage and NO ramps needed - built in. Works well for the Spyder with the low clearance. The back of the trailer hydraulically lowers and the built in rear gate folds down to extend the ramp portion. Easy to use. Our Spyder RT just fits and the nose of the Spyder fits in the V part of the front of the trailer. Not a lot of spare room, but works well. The Spyder fills the whole trailer even though this is a "two up" motorcycle trailer. A bonus for us is that our Gold Wing can be hauled on this trailer (with the use of the wheel chock that is included with the trailer) as well - however, only one bike at a time (unless you have two - 2 wheel motorcycles that are "short" enough). There is a standard 8 inch stone guard and an optional 20" stone guard. I did add the 20" stone guard on our trailer. Also, we purchased an optional spare tire which bolts to the bottom of the trailer. It has a steel frame with an aluminum deck with lots of tie down points!
    Here's some info on the model number and a few pics: Drop - Tail "Two - Up" Cruiser / Sport Bike Trailer, model number: 03-DCT2200-02
    Good luck on your choice of trailers - there are a lot of good trailers out there that work!!
    Attached Thumbnails Attached Thumbnails
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Lemoore, Ca
    What brand trailer does everyone use?? Looking at Carry on 6x12 wood deck.
