Results 1 to 11 of 11
    Mar 2014
    Vineland, NJ
    Default Rivco Trunk Rack
    Has anyone installed one of these? It sounds easy....any tricks or warnings, other than measure twice, drill once.
    https://rivcoproducts.com/shop-by-mo..._review_tabbed
    That's the biggest one... measure 146 times, and drill once!
    (Starting with an undersized bit, so that you can get the holes in EXACTLY the correct spot!)
    After this ne: just be careful about overloading the rack. The lid of the top trunk isn't really designed for carrying much, and it's better to be cautious!
    Good Luck; we're gonna need pictures of the results!
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    Just ordered one Monday chrome
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
    May 2013
    Sacrament0, CA
    Quote Originally Posted by southjerseyrider View Post
    Like you said, measure more than you drill and it's a straightforward install.
    Took me less than a half hour.
    Aug 2016
    Central Illinois
    Default Got the black one
    Haven't tried to install yet but I got the black one. Templates and instructions seem pretty straight forward. I am certianly not much of a wrencher but looks doable. I think they recomend a second pair of hands to keep it level and supported. So will have to wait for help.
    Out of the box looks good and seems well constructed. I like that it mounts level as opposed to the other one I looked at slanting.
    Hope I don't have to cover up mistakes in plastic.
    Sep 2014
    mathias,wv
    Default rack
    I would suggest to anyone adding anything that needs to drilled to first cover area with painters tape. Easy to mark holes before drilling.
    Good luck with it!
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default I installed the chrome version
    Took me less than 1/2 hour, and I'm going to repeat the advice of the people here.
    • Measure twice, cut once (or measure 5 or 6 times)
    • Use the template they provide, it worked very well
    • Use plenty of painter's tape anywhere the unit touches while installing. Prevents unnecessary scratches.
    • I elected to place some painter's tape on the inside of the unit where it touches my bike. If I ever remove the rack I'd like to not have places with the paint rubbed off (although I will have 4 holes).
    • Drill small holes, re-measure, drill bigger holes.
    • Make sure the right and left sides are drilled at the same height. I put a laser line level behind the bike so I could ensure they were the same.
    • One last thought. The front of the rack almost touches the trunk, so it's a bit tricky to stick a bungee hook in (I made some that work). If you can raise it even 1/16 or 1/8 inch it might help.
    Love the unit. Simple to use, looks great, doesn't cover up my Custom Dynamics high center brake light.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Chrome Rack
    Our chrome Rivco rack adds just enough carrying capacity. Use it for 2 rain suits and one cover, freeing up a lot of space in the 4 other storage areas. Chrome looks great on the Circuit Yellow.
    Kaos
    2014 RTS , Circuit Yellow
    South Okanagan, BC, Canada
    Bought the black one and installed it in the fall. Very easy to install and very functional.
    tip and OverHillAndDale pretty much have it all covered. I used 2 layers of painters tape at the spot where holes were to be drilled to prevent the bit from wandering at all and always use a small bit to start for your pilot hole. I usually use at least 3 sizes of bit and work my way up to the final size. That may be unnecessary but don't want to mess it up.
    I think it is a great design.
    Gary
    Oct 2014
    Brooklyn Center, Mn.
    Check the hand nuts regularly. Lost one
    Phoenix
    Default rivco expandable in black
    I love mine. I use it for my pet palace because when I changed the seat to a comfort seat I lost inches..and the pet palace will not fit on seat...fits on luggage rack fine. Maggie weighs 15-16 lbs.
